does a 94-95 jdm climate control plug up to a usdm dash?
you mean the the thing where the ac and stuff located at ?
I just used the carbon fiber only cause the Jdm is right hand drive.
every thing will plug right into except for the cable where you can move from cold to hot. the easy step is just use the jdm carbon fiber cover and everything else use your stock.
If you want the amber color only , why dont you just take the amber bulbs from the JDM clamate control ? Do you the jdm claimate control yet ? or you just want to change the usdm bulbs to Jdm amber?
I was under the impression that this would be another JDM ITR cluster, but from what I'm hearing, this is the JDM Sir-G cluster. The Sir-G cluster will require the second piece and some wiring.
jdmeg6118
11
Apr 18, 2008 12:25 AM
hondaj05
Aug 24, 2006 09:44 AM
