Bearing and Seal Kit (tranny)
Does anyone know if the b16a tranny bearing and Seal kit are interchangeable from a JDM and USDM?
I tried doing a seach on honda-tech but no luck.
Thanks
JG
Thanks
JG
Haven't purchased it yet but I can get it from Gearspeed for $200 shipped, JDM. I may be able to get it from a Honda dealer ship through a friend at a good rate but just wondering if the USDM is compatible with JDM tranny.
JG
JG
what kind of tranny is it a 90-93 cable style you can use 90-93 integra axle seals if its a newer style you use 94 and up integra axle seals or 00 si axle seals
same for the bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd »</TD></TR><TR><TD CLASS="quote">what kind of tranny is it a 90-93 cable style you can use 90-93 integra axle seals if its a newer style you use 94 and up integra axle seals or 00 si axle seals
same for the bearings</TD></TR></TABLE>
how sure are you about this? I was under the impression that the 90-91 S1 tranny was the smaller bearing/shaft version and that in 92 they switched to YS1 which was identical internals to the hydro versions only with cable actuation
Xemu
12
Jun 27, 2007 11:01 PM
hybrid1990crx
Feb 20, 2005 05:58 AM
