Help! 93 accord brake lights wont turn off!!
Old Oct 4, 2004 | 04:42 PM
Hybridcrx469's Avatar
Default Help! 93 accord brake lights wont turn off!!
Out of no where my 93 honda accord brake lights started to stay on even after i turned off the ignition. Nothing will seem to get them to turn off. The brake peddel seems to be in its normal position. I tried disconnecting the battery and that didnt work. Any help would be great, thanks
Old Oct 4, 2004 | 05:02 PM
Beach Accord's Avatar
Default Re: Help! 93 accord brake lights wont turn off!! (Hybridcrx469)
pm'd u
Old Oct 5, 2004 | 06:13 AM
Morthren's Avatar
sounds like the brake light switch on the pedal. If you look under the dash where the pedals are you will see the switch on the brake pedal. Pull off the connector and if they go off that will be your problem. Accord brake lights work when the pedal is pressed no matter what position the ignition is in. It may just need adjusting but it's likely to have gone bad.
Old Oct 5, 2004 | 03:24 PM
Default Re: Help! 93 accord brake lights wont turn off!! (Morthren)
The switch is the problem turns out. I disconnected the switch and the brake lights went out. But the button still seems to turn off the lights whenever i press the button in with my finger. Does that mean it just needs adjusting or is it shot?
Old Oct 5, 2004 | 04:22 PM
bill-71SS's Avatar
check where it contacts the pedal to see if it is hitting it right,it may be the plastic button is worn or missing on the contact
Old Oct 8, 2004 | 05:53 AM
Default Re: Help! 93 accord brake lights wont turn off!! (bill-71SS)
I found a few peices of rubber on my floor today. I found out that there use to be a rubber insert that goes inside the hole on the pedal. That insert had broken apart and the button was not making contact with anything. Problem is im not sure what to ask for when i go to the parts store
Modified by Hybridcrx469 at 11:07 AM 10/8/2004
Old Oct 8, 2004 | 10:41 AM
philadd's Avatar
something like that you'll probably have to get from a dealership... or a pick-a-part junkyard.
Old Oct 8, 2004 | 10:54 AM
Jay84ever's Avatar
Default Re: Help! 93 accord brake lights wont turn off!! (philadd)
Unplug it lol
Old Oct 8, 2004 | 01:37 PM
Morthren's Avatar
The switch comes complete... it will need replacing as a whole. It would be cheaper to go to a junkyard but you could order it online here...
https://www.1sthondaparts.com/
You can select OEM parts then select your car. Look for Electrical then Chassis Electrical you will find the stop lamp swicth in there. If your car doesn't have cruise control it will cost $12 with cruise you're looking at $38! I would say junk yard
Regulator1988
May 28, 2014 02:35 PM
type707
Jul 1, 2012 01:14 AM
courtney42
10
Jul 10, 2009 06:13 AM
PREACHERBREW
May 20, 2008 02:09 PM
CONLESS
Jun 15, 2005 09:48 PM
