how do I properly reset the timing belt tensioner
Old Oct 4, 2004 | 04:27 PM
spooncivic1's Avatar
Default how do I properly reset the timing belt tensioner
so i FINALLY got the crank pulley bolt off, and not i have everything set. and i cant seem to get the tensioner to reset itself....
everytime i go by what my haynes says it will move the loose end of the belt to the top or the right side of it???
how do you determine what the 3 degrees are?
HELP me please someone
Old Oct 4, 2004 | 04:32 PM
ABK's Avatar
ABK
Default Re: how do I properly reset the timing belt tensioner (spooncivic1)
you got loosen the timing belt tensioner and spin the engine by hand one way. Until the belt gets tight, then tighten it up. It sucks because everytime you do this timing seems to be off. Take a few tries if you took of your timing belt.
Old Oct 4, 2004 | 04:53 PM
i'll try that. any other suggestions?
Old Oct 4, 2004 | 06:03 PM
2lua's Avatar
Default Re: (spooncivic1)
turn the crank counter clockwise slowly and count three teeths on the cam, then tighten the tensioner bolt.
delsolboi
Mar 13, 2013 11:57 AM
chromeBuddha
Aug 4, 2008 12:43 PM
yosuthnmasa
Apr 8, 2008 07:29 AM
teler86
May 18, 2006 06:29 PM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
