BAD IAC? OBD1 Question
Old Oct 4, 2004 | 04:27 PM
TheHatchHog's Avatar
Default BAD IAC? OBD1 Question
I accasionally throw a code 14 which is IAC , I have b16a OBD1 converted 91 CRX. Is the fact that i have OBD1 on my car affect this since it is first gen B16a? Does the ObD1 and up cars have different wiring or clip on the IAC? Or do you just think it has gone bad. I do notice that when i am driving, once i shift into neutral to come to a stop, my car will have a bouncing flucuating idle, while coasting into park for red light or whatever. Once i get stopped, the idle goes back to normal at like 800-900, Has this ever happened to anyone? I orriginally thought it may be a vacume leak, but it stops when the car comes to a stop?
Modified by CrazyCRxXx at 5:51 PM 10/4/2004
Old Oct 5, 2004 | 08:14 AM
Default Re: BAD IAC? OBD1 Question (CrazyCRxXx)
I checked the FITV, that plastic plug is screwed in tightly. Then i took off the IAC, the screen did not look too dirty. But i cleaned it anyway. I ran the car. Idles high near 1500, when i pull the electrical plug off the IAC the idle drops down to about 900, and idles good. I am still throwing Code 14 which is IAC, any suggestions?
Old Oct 5, 2004 | 08:15 AM
Do i even need this IAC , has anyone ever bypassed it?
Old Oct 5, 2004 | 08:20 AM
TIRENECK's Avatar
i have the same problem. I dont know if the wires going to it supose to carry power cause i checked mines and no power coming from the plug. What im gona do is buy a new IAC and follow the wire all the way to check if its not cut.
Old Oct 5, 2004 | 09:01 AM
Default Re: BAD IAC? OBD1 Question (TIRENECK)
The weird thing is , the IAC is doing something, because when i plug , the plug back on while running, it starts to idle very strangly. When i checked to see if the plastic plug in the FITV was screwed in all the way, i noticed that wheni took off the flat metal cap on the back towards the firewall it was bone dry inside. I know that is temp sensitive and that plunger should pop open once and awhile. It looked as if there was no coolant flowing through in a while. Even though i am not throwing a code for that( dont even know if you could)That might be my problem as well, becuase if that bad boy stays closed all the time, it is letting extra air flow into the mani. and would explain my higher idle. But i am throwing a IAC code, so there definitely is something wrong there too> Man, I JUST WANT THIS TO IDLE NICE FOR A CHANGE
Old Oct 5, 2004 | 04:52 PM
Bump, Does anyone have any ideas what is causing my shitty idle. Anyway to test IAC other than unplugging it while the car is running?
Old Oct 18, 2004 | 10:27 AM
TurboHatch00's Avatar
Check your manual, I'm pretty sure there's a way to test and see if your iacv is bad. Not sure if it's the same ofr my car or not. I'm having the same problem though, but i've got obdII d16y8.
Old Oct 18, 2004 | 10:59 AM
crx_88_si's Avatar
electrically obd-0 and obd-1 are the same. if it plugs it and bolts on fine it works.
(obd0 and obd-1 CX motors are the same iacv).
dohc4life
Apr 7, 2011 04:22 AM
pmey
Oct 10, 2008 07:53 AM
boostedjdmdc2
Jan 6, 2008 08:34 PM
pokemon
Aug 29, 2004 10:13 AM
