Would you guys recommend polyurathane bushings for a daily driver?
My suspension setup on an eg 4dr:
DC2 H&R Race springs
Koni yellow shock set to mildest stiffness
ITR front strutbar
GSR rear swaybar
Neuspeed rear tower bar
Now I take this car to work everyday and the ride is pretty aggressive,does polyurathane bushings make a significant difference in handling enough to sacrifice the ride a little more,or should I just stick with my stock bushings?
Thanks and no hatin please
ITR front strutbar
GSR rear swaybar
Never had them in my own car, but always wanted to.....
My boy had them in his 92 teg and it rode like a brand new
car .....
car .....
ride didnt get more harsh with the bushings just firmer.
the car feels so much better tho with the new poly bushings in there cut alot of wheel hop too.
my car was over 12 years old so it needed some new bushings
After install car actually rides alot better over bumps, but expect some downtime while doing this. You will prolly break a few bolts if you suspension is rusted, plus it'a bitch to press those sleeves out, and rear suspesion isn't the easiest thing to put back together.
SNYPA
20
Feb 26, 2008 05:00 PM
