carsound cat.
Old Dec 13, 2001 | 07:35 PM
redteg1's Avatar
Default carsound cat.
2.5in collector in from the header and can go to fit a 2 and 1/4 in. exhaust out? or 2.5in on both sides?
Old Dec 13, 2001 | 07:38 PM
Chris's Avatar
Default Re: carsound cat. (redteg1)
~2.5" both sides...... you need to modify the B-pipe.
Old Dec 13, 2001 | 07:55 PM
gsr98vtec's Avatar
Default Re: carsound cat. (Chris)
who sells carsound cats online
Old Dec 13, 2001 | 07:57 PM
Chris's Avatar
Default Re: carsound cat. (gsr98vtec)
sig.
Old Dec 14, 2001 | 02:58 PM
redteg1's Avatar
how does that work? would i be able to run a say..n1 or greddy sp catback system or no?
Old Dec 14, 2001 | 04:12 PM
tr4il's Avatar
the n1 yes...greddy probably...not sure
Old Dec 15, 2001 | 10:33 AM
ndustryalGSR's Avatar
Default Re: carsound cat. (tr4il)
Check out this thread: https://honda-tech.com/zerothread?id=76912
You can buy a CarSound cat that's pre-flanged and will directly bolt up to your header and your cat-back exhaust -- no matter which brand. They all use the same spec flanges, or else none of them would bolt up the same.
Old Dec 15, 2001 | 12:57 PM
redteg1's Avatar
Default Re: carsound cat. (ndustryalGSR)
but im saying using this w/ a jdm 4-1 header w/2.5in. collector.....the carsound cat. has a 2.5inch in and a 2.5 inch out? how would that work out on a say...60mm catback?? they aren't the same sizes. sooo im confused and wondering how to set this up? along with wat catback system...and no i don't wanna run a testpipe....
crazybluecivic
Honda Civic (2001 - 2005)
Mar 18, 2008 08:05 AM
paopao
Nov 30, 2005 02:23 PM
Broken Devil
Oct 3, 2005 09:55 PM
ckyskater733
Sep 30, 2005 07:16 AM
iBrandon
Aug 11, 2004 11:53 PM
