Soft brake pedal
Old Dec 13, 2001 | 07:12 PM
Gennady's Avatar
New User
Default Soft brake pedal
I have PBR front pads and Raybestos rears, both are relatively new. My front rotors have less than 5k on them and they are Brembo blanks. My rears are OEM. I have regular DOT 3 fluid. My master break cylinder has about 7K on it.
Now, the top 15% of my break pedal does absolutely nothing, and is really soft. My breaks have great stoping power toward the bottom however. Even when I go over bumps, the pedal bounces up and down and makes and irritating sound.
What is wrong? Do I just need to bleed them. I have bled them before to see little success. Mabye I'm doing it wrong. Can anyone walk me through it?
Old Dec 14, 2001 | 03:41 AM
urbanlegend21's Avatar
New User
Default Re: Soft brake pedal (Wont be beat)
do you own a speed bleeder? if not you will need two people to get it done right.
Start at the drivers side rear working from wheel to wheel counter-clockwise around the car. As one person pumps and holds the pedal open and close the valve accordingly. Pretty simple. Use a different colored fuid for the change so you know that you have flushed the system properly.
Old Dec 14, 2001 | 11:12 AM
4doorH22's Avatar
Default Re: Soft brake pedal (urbanlegend21)
Top 15% is pretty normal. After a few thousand miles there is always some play in the system. Probably around 40% travel with no action is where you should be worried. The Helms bleeding procedure for our cars is driver rear, passenger front, passenger rear, driver front.
Old Dec 16, 2001 | 11:43 AM
Gennady's Avatar
New User
Default Re: Soft brake pedal (4doorH22)
Different color fluid...hhmmmm, I never thought of that. Good idea. Thanx guys.
94 IntegraLS
21
Jun 11, 2012 08:41 PM
sebTeggy
Dec 3, 2011 04:33 PM
bopbop93030
Mar 6, 2009 11:38 PM
terplaygroun_dc2
Mar 31, 2008 06:43 AM
