how to ID ctr cams, if they are the real deal or not.
Old Oct 4, 2004 | 07:53 AM
ImprtTuner88's Avatar
Default how to ID ctr cams, if they are the real deal or not.
Hey guys. When I bought my B16 swap, the guy threw in a set of what he called ctr cams. I have "NO" clue as to how to tell if they are in fact CTR cams, and the pics I have taken are not the best quality, but maybe someone can look at them and tell me what to look for, etc or if I just have a set of stock b16 cams. they are messed up slightly at 2 spots, you can see in one pic where the guy said it was installed with the cam caps backwards and ran for like 60sec's like that but said a good machine shop could fix. Any help guys?
Pic 1 shows the ends
Pic 2 show the other end.
Pic 3 shows the messed up part and the only ID # I saw on this cam.
The other cam has an "H" on it where the above pic showed the number "4".
Old Oct 4, 2004 | 09:52 AM
Reelizmpro's Avatar
Default Re: how to ID ctr cams, if they are the real deal or not. (ImprtTuner88)
I'd like to know to. I supposedly have CTR cams as well. The previous owner gave me the stock B16 cams so I didn't really question it. The car revs like crazy and makes good power in the upper RPM. Since your cams are out how about having them degreed and measure the lift. The CTR intake cam is 243 degrees and around 11.0 mm lift if I remember correctly.
Old Oct 4, 2004 | 11:03 AM
SoftieB16's Avatar
Default Re: how to ID ctr cams, if they are the real deal or not. (Reelizmpro)
yo from the looks of those cams i wouldnt put them anywhere near my car id rather buy new ones then deal with a machine shope doing something wrong and ******* up my motor. But the CTR cam is a more aggressive cam you can find thewm on Ebat brand new for like $450
Old Oct 4, 2004 | 12:02 PM
Steemo's Avatar
Default Re: how to ID ctr cams, if they are the real deal or not. (SoftieB16)
hopefully this helps you out
Old Oct 4, 2004 | 01:23 PM
LSVTEC 91 Civic's Avatar
Banned
your VTEC lobes look too small.
pr0honda
May 19, 2004 03:02 PM
89efb16
Dec 8, 2002 08:17 PM
IgniteTeg
Jun 14, 2002 04:20 PM
IgniteTeg
Jun 14, 2002 03:51 AM
