B18C1 + CRX + some tuning = better ETs.
First time to the drag strip with the GSR... it ran a whopping 14.80s.
Got it dyno tuned. Out of three runs:
Run 1 - 7:02p
Temp - 81'
Relative Humidity - 44
R/T - .516
60' - 2.677 (launched at 4000rpms)
330 - 6.603
1/8 - 9.756@78.35mph
1000 - 12.469
1/4 - 14.764@98.13mph (HA!)
Run 2 - 7:28p
Temp - 79'
Relative Humidity - 46
R/T - .394 (jumped the gun a bit)
60' - 2.279 (launched at 1600rpms)
330 - 6.156
1/8 - 9.287@78.87mph
1000 - 11.988
1/4 - 14.276@98.47mph
Run 3 - 9:08p (why i hate drag racing sometimes... 1.5hr later to make my next run)
Temp - 77'
Relative Humidity - 48
R/T - .720
60' - 2.454
330 - 6.319
1/8 - 9.469@78.45mph
1000 - 12.181
1/4 - 14.477@98.25mph
There's a 14.00 there. I just got to get the alignment set for drag racing and learn how to launch. I'm happy with it though. the MPH makes me happy enough and it runs like a raped ape where it really matters...at the track.
Run 1 - 7:02p
Temp - 81'
R/T - .516
330 - 6.603
1000 - 12.469
Run 2 - 7:28p
Temp - 79'
330 - 6.156
1000 - 11.988
Temp - 77'
R/T - .720
60' - 2.454
330 - 6.319
1000 - 12.181
what clutch do you have?
tires? & what is your front suspension?
2.2 to 2.3 is adverage.
I know your more of a auto-x guy but you should be able to hit better times than that.
easily a 14.0-13.9 car, maybe faster.
practice launching.
you can do 2.0 60ft's on street tires.
Modified by Disco Monkey at 3:41 PM 10/4/2004
practice launching.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">what clutch do you have? </TD></TR></TABLE>
OEM generic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">tires?</TD></TR></TABLE>
Ecstas V700s (uber stiff side walls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">what is your front suspension? </TD></TR></TABLE>
erm... GC w/ 450lb, Koni adjustables, ES bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I know your more of a auto-x guy but you should be able to hit better times than that.</TD></TR></TABLE>
Not a whole lot of places to practice launches. HPDEs don't depend on how well you can launch.
OEM generic.
at the track second gear is a pain, and third gear is also traction limited. i gave up once i was noticing i had to feather all thorugh 1 and 2 only to get half *** traction in third FWD sucks for drag racing
were thouse times with what transmission?
I have a J1 with no LSd and a similar setup (poor mans ITR) and im worried when i get to the strip im going to have horrible traction, pull a 2.6 60ft and a 15 second time.. Which would totally suck.
LSD make that much of a difference? I have good tires and suspention for drag racing.
-Eric
-Eric
find some of the lightest wheels you can and put a set of grippy drag radials and run high psi in the back tires. learn how to launch it as hard as you can without burning the tires too much. i always launch and feel the car before i check rpm, just saying you will launch at a certain rpm doesnt mean it will work. sometimes it helps to adjust the clutch close to the floor where you have acuarate leverage . it will run 13s, the key is light wheels and skill and no back bumper, removing the back bumber will shave at least 2/10s off for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mannyman »</TD></TR><TR><TD CLASS="quote">yeah should be mid 13's easy. Should really look into getting some small slicks..
manny</TD></TR></TABLE>
well, 13x9s...
i'm definitely lousy at launching. decent at RT... lousy at launching. I don't like the idea of clutch slippage. One day, i'll just set the alignment straight, get some real drag slicks, and go out there to see if i can launch the car.
well, 13x9s...
so are those kuhmo's sticky at all??? They look they would be good I guess w/out the previously noted stiff sidewall.
Heat them ******* up good next time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickBW »</TD></TR><TR><TD CLASS="quote">*sorry to get abit off topic..
hey Driven, is that you and your car I just read about in my new GrassRootsMag?
yup, thats our man!! he made it to the bigtime LOL !!
</TD></TR></TABLE>yup, thats our man!! he made it to the bigtime LOL !!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooptooth »</TD></TR><TR><TD CLASS="quote">so are those kuhmo's sticky at all??? They look they would be good I guess w/out the previously noted stiff sidewall.
oh, they are sticky... just got a very stiff sidewall (they are, afterall, road race/autox tyres).
I did a minor burnout with them...just a quick 2 second spin. Clean it off, get some of the old rubber off...
and yeah, that's the same car.
</TD></TR></TABLE>oh, they are sticky... just got a very stiff sidewall (they are, afterall, road race/autox tyres).
El Veterano de Sur Califas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven »</TD></TR><TR><TD CLASS="quote">
well, 13x9s...
i'm definitely lousy at launching. decent at RT... lousy at launching. I don't like the idea of clutch slippage. One day, i'll just set the alignment straight, get some real drag slicks, and go out there to see if i can launch the car. </TD></TR></TABLE>
are those 13x9 the Ecstas V700s (uber stiff side walls)??
If those are slicks(what they seem to apear) and not drag radials. Then those things should hook u!! Unless your just dropping the clutch at like 7K or something pretty high. I would lower the tire pressure alot more, and heat the slicks up pretty good. I had some some small MT slicks, with hardly any tread left and they hooked pretty darn good when they wanted to.
manny
well, 13x9s...
mannyThread
Civicman86
May 10, 2005 03:22 PM
Count Blah
19
Feb 9, 2003 01:39 PM
ActiveAero
Nov 9, 2002 06:44 PM
