What does it mean by BLUEPRINTING
Old Oct 3, 2004 | 10:13 PM
gamakichi77's Avatar
Default What does it mean by BLUEPRINTING
i'm a bit blur on this word........anybody here could help me?.thanks
Old Oct 4, 2004 | 06:05 AM
JimBlake's Avatar
Default Re: What does it mean by BLUEPRINTING (acidburns_di)
When the engine is manufactured, each part has an acceptable tolerance for it's size, shape, weight, or some critical dimensions.
'Blueprinting' just tries to improve the engine by imposing a tighter tolerance. In other words, you take parts that aren't perfect, but they're OK within Honda's tolerance. You make them closer to perfect.
Old Oct 4, 2004 | 04:33 PM
Default Re: What does it mean by BLUEPRINTING (JimBlake)
i'm still blur with it.........why they call it blueprinting, why don't just call it rebuilds
Old Oct 5, 2004 | 03:50 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acidburns_di &raquo;</TD></TR><TR><TD CLASS="quote">i'm still blur with it.........why they call it blueprinting, why don't just call it rebuilds</TD></TR></TABLE>
Same logic-applied to your statement
Why call it rebuilds, why not just call it blue-printing?
Old Oct 5, 2004 | 06:07 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acidburns_di &raquo;</TD></TR><TR><TD CLASS="quote">i'm still blur with it.........why they call it blueprinting, why don't just call it rebuilds</TD></TR></TABLE>Rebuilding just means take it apart & put it back together with new seals & bearings & stuff. That doesn't automatically mean you're improving things better than factory tolerances. So someone decided to start using a different word...
Old Oct 5, 2004 | 08:29 AM
EE_Chris's Avatar
A 'blueprint' calls out a specific dimension. Each part, however, has acceptable tolerance limits - as JimBlake has stated.
So blueprinting is selecting pieces/maching pieces in order to obtain the initial dimension - the tighter toleranced part - as Jim stated too.
For instance, bearing clearances - though they have an acceptable range of clearances, we could also say that it has a 'best' clearance which you would obtain by trying to blueprint the motor.
The piston to cylinder wall clearance has an acceptable range - but by blueprinting, you are trying to make sure ALL 4 of the cylinders have the same clearance #'s - and this particular number, once again, is aiming for the 'best' #.
Jasper_db1
Honda Motorcycles
Jun 30, 2008 10:08 PM
underbelly
Honda Civic (2006 - 2015)
16
Apr 1, 2008 05:53 AM
hondahp21
Dec 5, 2006 04:25 PM
CW96
Apr 12, 2004 11:41 PM
