Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Switching tires -- how far will my speedo be off?
Old Dec 13, 2001 | 03:24 PM
slowSER's Avatar
Default Switching tires -- how far will my speedo be off?
I suck at math, so I'm looking for a math whiz to help me ...
I just got some Kumho Ecsta V700 tires for the Lightning ("won" the bidding war on CRX driver Marshall Cone's certificate for free Kumhos ), and I want to know how far my speedo will be off with them. Since I have to haul the cones for this weekend's NASA autocross, I may have to drive on them since there probably isn't room for 100+ cones, timing equipment, PA speaker, fire extinguishers, jack, loaner helmets and a set of Lightning rimz/tires in the bed.
Anyway, stock tires have a diameter of 28.4" ... the Kumhos are 24.6" (how to lower a truck by 4" in under a half hour ). Gear ratios are:
1st - 2.71
2nd - 1.53
3rd - 1.00
4th - 0.71
Final drive - 3.55
Will I be staring at 4,000 rpm at 80 mph like the SE-R?
[Modified by slowSER, 7:25 PM 12/13/2001]
Old Dec 13, 2001 | 03:55 PM
Drew M's Avatar
New User
Default Re: Switching tires -- how far will my speedo be off? (slowSER)
My answer is that due to the Bling-Bling! factor you shouldn't be cruizin' at more than 35MPH so you should be fine . . .
Pimp Away!
Old Dec 13, 2001 | 04:10 PM
SOHCArchangel's Avatar
Default Re: Switching tires -- how far will my speedo be off? (Cobra)
LOL
Old Dec 13, 2001 | 05:00 PM
slowSER's Avatar
Pimp Away!
Yo, I only gots da stock "L" wheels for da sticky tires, so I ain't goin ta be bling-blingin to much. I could see if it wuz rollin on sum chrome polished dubz or sumpin.
[Modified by slowSER, 9:01 PM 12/13/2001]
Old Dec 13, 2001 | 05:59 PM
4WDrift's Avatar
Leave it to a psych major , (28.4 - 24.6) / 28.4 = 13.4% high, so figure that over your normal rpm's Pat.
Old Dec 13, 2001 | 08:44 PM
WRXRacer111's Avatar
I can't help you on the gearing issue, but let it be known that I think Pat is a CRAZY BEEEYOTCH. You are the first person I have heard of to have r-compounds tires on a Lightning that is their "tow vehicle".
Let's all be rational for a moment... you might be a racer if... YOU HAVE RACE TIRES FOR YOUR TOW VEHICLE!
Old Dec 14, 2001 | 03:47 AM
slowSER's Avatar
Ooo, found this: http://www.4lo.com/4LoCalc.htm
Old Dec 14, 2001 | 09:14 AM
MrBite's Avatar
or this: http://www.syty.org/old/calculator.html
Old Dec 14, 2001 | 10:57 AM
maxQ's Avatar
Let's put it this way. Lowering your overgrown hairdryer with R tires STILL won't be enough to beat a box on three wheels with no tach...
Andy
Old Dec 14, 2001 | 11:18 AM
4doorH22's Avatar
Default Re: Switching tires -- how far will my speedo be off? (MrBite)
also http://www.miata.net/garage/tirecalc.html
Old Dec 14, 2001 | 11:26 AM
Geezer's Avatar
...Anyway, stock tires have a diameter of 28.4" ... the Kumhos are 24.6" (how to lower a truck by <U> 4"</U> in under a half hour)...
Maybe 1.9"?
Old Dec 14, 2001 | 11:38 AM
4doorH22's Avatar
Default Re: Switching tires -- how far will my speedo be off? (Geezer)
As long as the much-celebrated Lightning's inertial guidance system isn't upset...
Old Dec 14, 2001 | 12:07 PM
slowSER's Avatar
Maybe 1.9"?
Look at the first line of my first post.
John 07
Jan 9, 2007 07:07 PM
TurBoTeG
Sep 28, 2004 06:10 PM
GumballNA
Oct 21, 2002 05:36 PM
Wildohiorice
Aug 16, 2001 10:19 AM
Dirty GS-R
Jun 24, 2001 08:21 AM
