Crx/Civic Coilovers... Show pics please.
Old Oct 3, 2004 | 12:00 PM
Rob.'s Avatar
Default Crx/Civic Coilovers... Show pics please.
I am currently using H&R Ultra Low coilovers....Whenever I go over a big hump in the road, the front coilovers seem to be bottoming out ! I hear a loud thump !!!!
So I am thinking of changing and getting GC/Koni setup, or TEIN SS instead.
how low do these coilovers go ???
Please post pics of your setup,pro's,cons and detailed description with pics.
I can still go down another 1/2 inch in the front and 1 inch lower in the rear...
Old Oct 3, 2004 | 12:07 PM
sloweredcivic's Avatar
it could be your struts it sounds to me like your not bottoming out out but comming up off of the spring i would just slow down for those big bumps
Old Oct 3, 2004 | 12:10 PM
RedRacerCivic's Avatar
did you cut your bumpstops??
Rob.'s Avatar
Default Re: (sloweredcivic)
could it be my driveshaft hitting something on my strut ?
It sounds like the shock is hitting the top or somhing..
Old Oct 3, 2004 | 12:12 PM
Rob.'s Avatar
Default Re: (RedRacerCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRacerCivic &raquo;</TD></TR><TR><TD CLASS="quote">did you cut your bumpstops??</TD></TR></TABLE>
no ... Am I suppose to ?
Old Oct 3, 2004 | 12:16 PM
eLUDEnu
Guest
Posts: n/a
Default Re: (Rob.)
[QUOTE=Rob.]could it be my driveshaft hitting something on my strut ?
Didnt know you had drive shafts? you have axles. and It sounds like you are bottoming your struts out. are you still using factory struts?
Old Oct 3, 2004 | 12:19 PM
Rob.'s Avatar
Default Re: (eLUDEnu)
These are not factory struts ! It is a full coilovers system, (no sleeves)
Old Oct 3, 2004 | 12:50 PM
ProjectCRXtacy's Avatar
Default Re: (Rob.)
You might want to check and see if the upper control arms are hitting the top of the car. All this really only means is that you should get stiffer springs so when you hit the bump, you don't get stuck in an underdamping situation. If you have adjustables, put them on the stiffest setting for now till you get a higher spring rate spring.
Personally, I think the car is too low and you're losing precious traction in the straights with all of that negative camber. If you correct the camber at that hieght though, you might see the upper A arm hit the lip where the fender matches up with the chassis.
Good luck.
Edit: ....and yes, you should cut your bumpstops. the Illumina Shocks that I have tell you to do that if you're going to lower the car so you have more travel
Old Oct 3, 2004 | 12:56 PM
shocker's Avatar
It is the upper control arm,i know what your saying my freind had his eg really frickin low and every time he would go over a bump,it made a really loud metal type thump.After a while,there was a hole in the metal right by his strut bar!
Old Oct 3, 2004 | 12:58 PM
Rob.'s Avatar
Default Re: (shocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shocker &raquo;</TD></TR><TR><TD CLASS="quote">It is the upper control arm,i know what your saying my freind had his eg really frickin low and every time he would go over a bump,it made a really loud metal type thump.After a while,there was a hole in the metal right by his strut bar!</TD></TR></TABLE>
do you have a pic of it ? I think you are right.
Old Oct 3, 2004 | 01:58 PM
sicc83's Avatar
Default Re: (Rob.)
I'm 99% sure it's the conrol arm. The shock is too short to bottom out or hit the bumpstop. You don't need to cut the bumpstops because they are already the correct length.
You can either raise it up a little or cut the strut towers. I know you wouldn't do that though. So just raise it like 1/2" and you'll be good. My control arms never hit BTW.
Old Oct 3, 2004 | 02:00 PM
Rob.'s Avatar
Default Re: (sicc83)
I just went to check abd the control arm boot is like 1/4 " away from the chassis !!!! I must raise it abit...
dub from laos family
Suspension & Brakes
Oct 14, 2006 02:03 AM
irishbobby23
Sep 8, 2006 11:55 AM
Allstar
May 4, 2005 10:48 PM
n-line4
Feb 23, 2005 10:32 PM
Rob.
May 7, 2004 03:51 AM
