Who Can Give Me a Compression Ratio? COMPLICATED
Old Oct 3, 2004 | 11:08 AM
1 Cam Wonder's Avatar
Default Who Can Give Me a Compression Ratio? COMPLICATED
Hey guys, first post.
Im hoping someone here knows there **** really well enough to answer this question.
Ive got a d16a6 block, not machined or touched at all .
There Arias high comp but made a for a d16y8, heres the specs on them.
Displacement: 97.19 1593
Bore: 2.995 75.06
Stroke: 3.394 89.99
Rod Length: 5.394 137.01
Comp Height: 1.154 29.3
Compression: 11.00 11.00
Now from what Ive heard, mating an A6 head to a Y8 block drops compression like a mug right.... But these are like dome pistons, will I slap valves? Its an A6 head milled .040, delta 272 cam and 1 mm oversized valves.
If compression is still nice and up there. Ill go with nitrous, if not Ill go to boost (budget)
Obviously I jsut threw this shitty thread together because Im rather pissed but Ill answer any questions you need to know.
THanks
Modified by 1 Cam Wonder at 1:38 PM 10/3/2004
Old Oct 3, 2004 | 04:48 PM
dr_latino999's Avatar
Default Re: Who Can Give Me a Compression Ratio? COMPLICATED (1 Cam Wonder)
Ok, first, these are the resources I used to calculate your compression for future reference.
Arias Spec Sheet - http://www.ariaspistons.com/sporthonda.htm
D-Series Compression Calculator - http://www.knology.net/~jediklc/D.htm
Second, this is your final compression - 10.3936.
Firstoost
Apr 26, 2006 05:30 PM
DeadVet
Mar 30, 2005 04:37 PM
DeadVet
Feb 9, 2005 12:34 PM
red91g2
Mar 3, 2003 12:12 PM
