main relay question
My 89 accord exi (canada) did not start yesterday , i suspect it is the main relay
because i don't hear the big clic it usually does when i put the key on. (when i say big click i mean the two clicks it does for the fuel pump to prime:turn the key on
it goes once then a couple seconds later after the pump has primed it goes again)
Now my question might be stupid but is the main relay the fuel pump relay or is there another relay for the pump??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 exi nut »</TD></TR><TR><TD CLASS="quote">Now my question might be stupid but is the main relay the fuel pump relay
Yes, and it sounds like it crapped out on you.
It was in fact the main relay that crapped out ,i did a search and found out what
to weld on the board . I put some fresh welds to it and it works. Thanks for the
reply Chiovnidca , at least now when it does it again i'll know where to look.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 exi nut »</TD></TR><TR><TD CLASS="quote"> at least now when it does it again i'll know where to look. </TD></TR></TABLE>
If you resoldered the joints good you probably wont have to mess with it again.
CoolRedXylophone
Jan 22, 2006 06:45 PM
