H22 Swap: DETAILED instructions on shaving Prelude driver's side mount to fit?
Old Oct 2, 2004 | 10:57 PM
OutlawCL's Avatar
Default H22 Swap: DETAILED instructions on shaving Prelude driver's side mount to fit?
I'm doin a 2000 USDM h22 swap into my 97 CL, and I've searched and have been told by others that I need to shave the Prelude driver's side mount to fit. Well, how? I have both mounts, I just need detailed instuctions on how to do it, and I haven't found anything, no pics, nothin. Anybody know? Thanks.
Old Oct 2, 2004 | 11:32 PM
HAccord96's Avatar
Default Re: H22 Swap: DETAILED instructions on shaving Prelude driver's side mount to fit? (OutlawCL)
It is very simple. The Prelude driver side mount has the hole that to insert the bolt through and it happens to be slightly longer than the Accord/CL stock motor mount. All you have to do is use a bench grinder and grind the excess metal off until you can get the Prelude mount to fit into the CL's driver side mount location. Good luck with the swap.
Laskowski
Mar 11, 2011 03:10 PM
T9U4ReBgO
Sep 8, 2010 06:49 PM
Luserkid
Dec 9, 2004 10:07 PM
