not a honda but is this intake manifold even efficient? (experts)
Old Oct 2, 2004 | 10:52 PM
accordfreak's Avatar
Default not a honda but is this intake manifold even efficient? (experts)
This intake manifold is on a g35 coupe and the rest of the turbo kit is greddy. Is this manifold design efficient?
Old Oct 2, 2004 | 11:02 PM
mattcalica's Avatar
kinda looks like a tennis racket
Old Oct 2, 2004 | 11:11 PM
BoostedJeff's Avatar
Default Re: (mattcalica)
what motor/car is that?
EDIT: Reading ownz me
Old Oct 2, 2004 | 11:12 PM
Ekasey's Avatar
I would say it looks to be a very effificient design seeing as the plenum is large enouhg so the engine wont starve for air
Old Oct 3, 2004 | 12:33 AM
Agtronic's Avatar
Default Re: not a honda but is this intake manifold even efficient? (accordfreak)
That's a really nice piece! I like how they connected the back of it.
Old Oct 3, 2004 | 12:42 AM
DD_JonnyLee's Avatar
Default Re: not a honda but is this intake manifold even efficient? (Agtronic)
what does a stock intake manifold look like for these cars??? kinda looks like they just took the plastic cover off....i dunno
Old Oct 3, 2004 | 12:48 AM
Default Re: not a honda but is this intake manifold even efficient? (Raped-Ape)
this is stock.. the plenum
Old Oct 3, 2004 | 04:13 AM
HybridKOOP's Avatar
... awaiting Tony1 to chime in
Old Oct 3, 2004 | 05:35 AM
nonvtecD's Avatar
What's to stop the first couple runners from getting a bigger charge of air compared to the ones farther down. I feel like those would run leaner because they would suck as much air as they could and not leave as much for the runners farther down, thats what it looks like to me.
Old Oct 6, 2004 | 11:39 AM
BoOsTeD_eK's Avatar
Default Re: (D15B7turbo)
i AGREE...THEY SHOULD OF TAPERED IT AS IT GOES TO THE REAR CYLINDERS. dEFINITELY A GOOD STARTING POINT TO MAKE REFINEMENTS TO.
Old Oct 6, 2004 | 12:02 PM
rextec's Avatar
i think it looks good because it seems to me that it would be evenly pressurized being that it is FI.
Old Oct 6, 2004 | 12:22 PM
Turbowa's Avatar
Default Re: (rextec)
Resembles the accord V6 IM pretty close. I would have to assume its efficent to some extent.
Old Oct 6, 2004 | 01:52 PM
Smokinsax's Avatar
The Boot
new type of log mani
Old Oct 6, 2004 | 02:34 PM
adictionbass's Avatar
Default Re: (Turbowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa &raquo;</TD></TR><TR><TD CLASS="quote">Resembles the accord V6 IM pretty close. I would have to assume its efficent to some extent.</TD></TR></TABLE>
agreed
Old Oct 6, 2004 | 03:33 PM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">i think it looks good because it seems to me that it would be evenly pressurized being that it is FI.</TD></TR></TABLE>
not too many I-4 intake manifolds are tapered
Old Oct 6, 2004 | 03:37 PM
91civicDXdude's Avatar
Default Re: (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">
not too many I-4 intake manifolds are tapered</TD></TR></TABLE>
only all b and d series...
Old Oct 6, 2004 | 03:42 PM
stizzit's Avatar
Default Re: (91civicDXdude)
It's got wiggin's clamps, at $150 each, dizzzam.
Bling Bling
Old Oct 6, 2004 | 03:50 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (stizzit)
I'd be deathly afraid of leaning out the rear two cylinders. If the air didn't have to go directly past all four other cylinders to get there it wouldn't seem like such a big deal, but it really isn't something that I'd trust on my expensive car without some serious testing data.
Old Oct 6, 2004 | 03:59 PM
Johnyquest's Avatar
Default Re: (Archidictus)
How would the rear cyl's lean out? It's just air... not fuel going through that manifold?
Matt
Old Oct 6, 2004 | 04:26 PM
MidShipCivic's Avatar
How many of you are a specialist in fluid dynamics etc and all the importants of making an intake manifold.
I think this is the wrong place to ask.
Old Oct 6, 2004 | 04:49 PM
CalGSR99's Avatar
Default Re: (MidShipCivic)
You dont have to be a fluid dynamics expert (even though i have taken a few courses) to see what is happening. Anyways, im not an expert to any extent but i can tell you that each intake runner has a max flow rate. Once that is reached the air will divert to the following cylinders and so on.
So two things can happen.
1. The total air rate going in to the engine is less than the combined MAX RATING of air flow from all cylinders, so this would cause the last ones to lean out.
2. The engineers that designed this intake runner knew about this ahead of time. And made sure that each runner got its correct air flow by making sure the actual intake can pull in more than the MAX combined air flow to support all cylinders.
I put my money on number two.
Old Oct 6, 2004 | 05:08 PM
TrueNorthStar's Avatar
Default Re: (CalGSR99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CalGSR99 &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't the back runners run rich and the lean ones would be in the front in this case? Seeing how if the rear runners were getting less air.... with the same amount of fuel as the front runners.
Old Oct 6, 2004 | 05:09 PM
danoonez's Avatar
Default Re: (TrueNorthStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't the back runners run rich and the lean ones would be in the front in this case? Seeing how if the rear runners were getting less air.... with the same amount of fuel as the front runners.</TD></TR></TABLE>
My thoughts exactly.
Old Oct 6, 2004 | 05:37 PM
AVATAR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit &raquo;</TD></TR><TR><TD CLASS="quote">It's got wiggin's clamps, at $150 each, dizzzam.
Bling Bling </TD></TR></TABLE>
You gotta hook up? I thought dealers paid like 180 . . .
Old Oct 6, 2004 | 07:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CalGSR99 &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to be a fluid dynamics expert (even though i have taken a few courses) to see what is happening. Anyways, im not an expert to any extent but i can tell you that each intake runner has a max flow rate. Once that is reached the air will divert to the following cylinders and so on.
I put my money on number two.</TD></TR></TABLE>
You can never tell by looking at things like this, how do you know they were engineers?
Modified by MidShipCivic at 9:04 PM 10/6/2004
