is a b16 head bettter to build than a b18c1
Old Oct 2, 2004 | 10:27 PM
joshonater's Avatar
Default is a b16 head bettter to build than a b18c1
i wanted to build the head on my 94 gsr some guy told me that a b16 head is better to build than a gsr is that true. what would be some good cams and valves and valve spings is porting werth it thanks
Old Oct 2, 2004 | 10:57 PM
1 2 NV's Avatar
Default Re: is a b16 head bettter to build than a b18c1 (joshonater)
search
Old Oct 3, 2004 | 02:35 AM
Mike K's Avatar
depending on your application. the c1 head has a more direct shot into the combustion chamber, along with less cc's. the b16/c5 head flows way better in stock form, or even slightly modified form. but in an all out max hp application, i think b18c1 head dominates. just make sure the head is done right. 80% of people DON'T have it done right.
if you don't believe me that c1 head is better, do a search for my b20 destroker 1.8 motor which made 212/143 at the wheels. or even better yet, call tom at portflow or larry at endyn. they'll tell you.
bottom line is, if you're gonna be less than 12:1 and have a goal of less than 195whp, stick w/ b16 head. if you're a little crazy and have an urge to spend TOO MUCH money on your motor, go b18c1 head.
Old Oct 3, 2004 | 02:43 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
i prefer the p72..
Old Oct 3, 2004 | 11:36 AM
Fkned's Avatar
Default Re: is a b16 head bettter to build than a b18c1 (bruceleeroy)
GSR head has much more potenial then B16.
1990hondaHF
Aug 9, 2005 11:32 PM
MikesGSRbuiltEG
Jul 8, 2005 02:29 PM
0bLiViOuS
Jun 17, 2005 01:10 PM
ragerized
Jun 4, 2004 09:47 AM
thehatchninja
16
Aug 21, 2003 06:15 PM
