crx hf
Old Oct 2, 2004 | 09:14 PM
im2pogi's Avatar
Default crx hf
quick question
i got a question... i got a 90 crx hf and somebody told me that in order to do a swap in that car i have to change all my parts to an si? is that true?
if true what parts must i change to an si?
Old Oct 2, 2004 | 09:17 PM
I Have an STD's Avatar
wrenchin'
Default Re: crx hf (im2pogi)
holy ****, search noob
its the top right icon. there is TONS of info. and just to get you started. an hf is MUCH better to have than a dx
Brett
Old Oct 2, 2004 | 09:36 PM
im2pogi's Avatar
Default Re: crx hf (I Have an STD)
dude i did i typed in crx hf, crx swap, crx ,and didnt find any info on my question.
what do u type to find the information im looking for maybe im just doing it wrong.
Old Oct 2, 2004 | 09:43 PM
kulangot's Avatar
what kind of swap, if u do a Dswap u dont have to if u do a Bswap guess what u have to.
Old Oct 2, 2004 | 10:09 PM
EF*ThIs's Avatar
lol
Old Oct 2, 2004 | 10:27 PM
Ivan's Avatar
senior gold member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">holy ****, search noob
Brett</TD></TR></TABLE> 9/2003 your post is about as useless as his thread. I'm getting tired of the "search noob" You guys are starting to sound just like the noobs.
anyways, depending on your swap. You might just need to switch out the front hubs to SI spec. you didn't specify what you were gonna swap to.
Old Oct 2, 2004 | 11:51 PM
Burlyirishdude's Avatar
You get used to the flames, it's part of the quest for answers.
I also have an Hf. It sounds like you were talking about a b-series swap. If that's true, you gotta check and replace a lot of stuff and look into every piece of your car
1.) which block you're getting. Search on this forum, everything from A6 to Zc. You'll find what you're looking for.
2.) Go over ALL the SPECS on the MOTOR that you have! All of them, doesn't matter how minute it may seem. and don't guess which block you have. Find out.
3.) Brakes,suspension, front hub assembly needs to be changed out for the SI (knuckle)Hub assembly. * if you're doing the B-series swap.* Bigger axels for that bigger tranny. And you get bigger brakes!
4.) Research it until you can name the specs on every honda/acura block/axels from late 80's up to the mid 90's. It gets boring going from d-f-b-k series blocks...you'll know'em real well.
No such thing as a stupid question. If you look hard enough you'll score the answers you need. Good luck on your hf project. It's a bitch but everyone will be crying when the only letters they see are the ones on your plates and the little HF sticker on the panel in the back.
Old Oct 3, 2004 | 12:06 AM
Steemo's Avatar
Default Re: crx hf (Burlyirishdude)
just a tip when you do search make sure you clicked archived content... that might help you find a lot more stuff... it sucks sifting through pages of crap but usually you can find what you need. but ya if you are planning on swapping pretty much anything you need to swap out your knuckles and hubs to crx dx or si ones because hf axles are dinky... but other than that the hf is a good platform cause its light and the wiring harness is all ready to go just plug and play.
Old Oct 3, 2004 | 07:08 PM
im2pogi's Avatar
Default Re: crx hf (Steemo)
thanks for yallz information.. and yes im planning to do a b series swap on my hf. so i guess i just got to change the knuckles and hubs on my hf. maybe i just get a front clip and drop the whole front clip on my car. there is a really good site. flashoptions.com that sell pretty good prices. and thanks again for the good information and advice. it will help me alot.
so one was telling me that the hf exhaust is too small tho? what does he mean by that? i found out that the cat convertor is on the header in the front. is that what he means
Old Oct 3, 2004 | 07:42 PM
Steemo's Avatar
The exhaust is seriously just over an inch in diameter. If you're dropping a B-series in there, you'll definitely want a larger exhaust all the way back. HF exhaust was made for a 62hp engine. Even the lowest HP rated B-series is close to double that.
Old Oct 3, 2004 | 07:52 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steemo &raquo;</TD></TR><TR><TD CLASS="quote">The exhaust is seriously just over an inch in diameter. If you're dropping a B-series in there, you'll definitely want a larger exhaust all the way back. HF exhaust was made for a 62hp engine. Even the lowest HP rated B-series is close to double that.</TD></TR></TABLE>
More like three times, hell the HF dyno's at 47whp
Old Oct 3, 2004 | 07:53 PM
coot_er's Avatar
i remember driving to the muffler shop right after my swap with open header
my rex sounded like a tractor
Old Oct 3, 2004 | 10:46 PM
Default Re: crx hf (coot_er)
yeah....i'm droping my baby off on wed.....so a tractor uhn? Sikk.....hahahaha......
Hope the drive of 3 mi i don't get pulled over 5 times....
BTW: nice name.....i love it. COOTER.....hahaha it just rolls of the tongue...and those who know what it is....should laugh.(i did)
seeareex
14
Feb 19, 2008 07:26 PM
the niz jiz
11
Nov 7, 2006 07:02 PM
Evolution Type R
May 2, 2006 11:43 PM
Jaker
Jun 12, 2005 01:34 AM
thrty8street
Feb 5, 2004 01:03 PM
