wtf...my car is blowing white smoke everywhere..help
if youre leaking oil into the bay, and smoking out the rear, then its most likely a head gasket... the reason for the putting is that when the engine was pressurized and you shut it off.... the antifreeze flowed into the cyliners.... after a mile or so, it should have burned off and ran fine...
well i went back to friends where i left it and had no oil of course, oil wwas all over engine so i really couldnt tell where it was coming from...i checked all vacumm lines,wiring, etc...nothing obviously wrongso i put some oil in it and started it up, let it run for a minute...then i hit the gas a little , it still did the putting thing and smoking still...theres oil spitting out of the brether on my valve cover, i looked in the valve cover and white smoke came rolling out....wtf??i checcked my radiator there was no signs of oil......today im a do a compression test...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotik sol »</TD></TR><TR><TD CLASS="quote">......today im a do a compression test...</TD></TR></TABLE>
Try a leakdown test too. Sounds like you chunked a piston.
alright today i did compression test and cylinders 1,2,and 4 have 220 cylinder 3 is dead..compression nohigher than 5-10...this means piston is cracked or piston rings are shot correct?? there was also oil on top of the piston.....
Could be a piston ring. I melted the rings in 2 pistons in my EP and scored the cylinder walls, just hope it isn't that. I'll keep my fingers crossed for you since i know how much work is involved.
Can you say three months without my car??? ....and counting...
*sigh*
*sigh*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmech »</TD></TR><TR><TD CLASS="quote">cyphears car did that. Turned out to be a cracked sleeve. </TD></TR></TABLE>
You have any pics of that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djvtoner »</TD></TR><TR><TD CLASS="quote">Could be a piston ring. I melted the rings in 2 pistons in my EP and scored the cylinder walls, just hope it isn't that. I'll keep my fingers crossed for you since i know how much work is involved.
*sigh*</TD></TR></TABLE>
how much boost are you running? was it a stock bottom end?
*sigh*</TD></TR></TABLE>how much boost are you running? was it a stock bottom end?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">11 lbs on a stock b16/r combo and are you really surprised it killed itself?</TD></TR></TABLE>
im not.
was the fuel map changed at all ?
im not.
It was a stock bottom end and the boost was running on what ever the e-manage was set to, which i think was 6psi. Supposedly the car could run on stock internals... it might've been a bad judgement call on my part for letting the person install it that i did...
...but i thought they knew what they were doing...that was some $3000 mistake
(shaking head in disgust)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
You have any pics of that?</TD></TR></TABLE>
Yeah, right here.
https://honda-tech.com/zerothread?id=881468
Yeah, right here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">Yeah, right here. </TD></TR></TABLE>
yeah....ummm.....ouch
Yeah, right here.
https://honda-tech.com/zerothread?id=881468</TD></TR></TABLE>
Thanks.
Yeah, right here.
Thanks.
yea, so im starting w/ the headgasket this weekend......if thats not the prob, i have to decide on what to do...another stock block,replace w/aftermarket internals,or get serious and do a total build........grrr..well lets hope its the headgasket..
