back from the dyno 400hp ls/vtec stock sleeves!!!
Old Oct 2, 2004 | 05:37 PM
ek9turbo's Avatar
Default LS/VTEC 400HP on stock sleeves!!!, dyno graph inside
ls/ vtec, drag kit t3t4 54 trim 63 ar, type r head and cams, 9:1 cr, stock sleeves, 750cc injectors, eagle rods, je pistons, 2.25" open downpipe
404.5 hp and 295.5ft-lbs @20psi but boost drops back to 18psi after7500rpm
and here is a comparison with a built h23 (drag kit)
pic of the car
Modified by ek9turbo at 2:48 AM 10/3/2004
Modified by ek9turbo at 2:50 AM 10/3/2004
Modified by ek9turbo at 3:30 AM 10/3/2004
Modified by ek9turbo at 4:52 PM 10/3/2004
Modified by ek9turbo at 10:26 PM 10/17/2004
Old Oct 2, 2004 | 06:42 PM
CompressionFed's Avatar
Default Re: LS/VTEC 400HP on stock sleeves!!!, dyno graph inside (ek9turbo)
Looks good. Where you at in Va?
Old Oct 2, 2004 | 06:45 PM
spooledex's Avatar
upgrade the dp and you will make more hp definitely. Nice numbers for stock block.
Old Oct 2, 2004 | 07:08 PM
bigTom's Avatar
Default Re: LS/VTEC 400HP on stock sleeves!!!, dyno graph inside (spooledex)
looks good... oh... and nice screenname by the way
Old Oct 2, 2004 | 08:10 PM
M.A.R.C.'s Avatar
Default Re: LS/VTEC 400HP on stock sleeves!!!, dyno graph inside (ek9t)
wow... nice numbers
your setup is similar to what i'm looking to build.
bump for you
Old Oct 2, 2004 | 08:24 PM
johnmay19's Avatar
Default Re: LS/VTEC 400HP on stock sleeves!!!, dyno graph inside (CivicRyda2k)
congrats good numbers with the drag kit.
Old Oct 2, 2004 | 09:34 PM
simike's Avatar
Default Re: LS/VTEC 400HP on stock sleeves!!!, dyno graph inside (johnmay19)
What bore is the block? 81mm or did you have to go oversize to 81.25mm or 81.5mm? Nice numbers. I hope my setup comes close to that.
Old Oct 2, 2004 | 10:49 PM
adseguy's Avatar
Default Re: back from the dyno 400hp ls/vtec stock sleeves!!! (ek9turbo)
nice numbers! If you had a 3" DP you could easily make 435+WHP
What ems are you running?
Old Oct 3, 2004 | 12:08 AM
Smokinsax's Avatar
The Boot
dammit...all the questions I had have already been asked.
Old Oct 3, 2004 | 12:37 AM
reaction360's Avatar
Default Re: (Smokinsax)
i'm curious, what wastegate are you running? is it the standard deltagates that comes with that kit? or did u upgrade?
Old Oct 3, 2004 | 03:22 AM
ek9turbo's Avatar
Default Re: (reaction360)
81.5 je pistons, im using a tial wastegate with 9psi spring, hondata s100 3bar map
thanks for the comments
Old Oct 3, 2004 | 08:29 AM
simike's Avatar
Default Re: (ek9turbo)
Thanks for the quick reply. Iwas told to go .5mm over on stock sleeves when going to forged pistons and wanted to see what others were doing. Looks like it's the way to go.
Old Oct 3, 2004 | 09:49 AM
11psiTurboSI's Avatar
Default Re: (simike)
Nice
Old Oct 4, 2004 | 07:00 AM
ek9turbo's Avatar
i think 3" downpipe will make more power. but the problem is the small intercooler
it seems to me that it stopped flowing at high rpm thats why its flat.
Old Oct 4, 2004 | 09:43 AM
Turbocivic94's Avatar
nice power on stock sleeves
Old Oct 4, 2004 | 12:32 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9turbo &raquo;</TD></TR><TR><TD CLASS="quote">i think 3" downpipe will make more power. but the problem is the small intercooler
it seems to me that it stopped flowing at high rpm thats why its flat.</TD></TR></TABLE>
Nice #s, Shad tuned some magic for you I see! My Stock block B16A with 9:1 Endyn pitons, Eagle rods 550 cc injectors made 370whp and 276ft-lb torque with 21psi and my boost was dropping too up high. That was a DRAG 3 kit, small as T3/T04B S trim turbo.
If you need a bigger intercooler let me know! I will hook you up on a few different brands I carry!
Old Oct 4, 2004 | 12:33 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">looks good... oh... and nice screenname by the way</TD></TR></TABLE>
Yeah when I saw the SN at first I thought it was you! But WTF would you dyno at Abacus when you guys have your own dyno close? lol
Old Oct 4, 2004 | 01:32 PM
simike's Avatar
Default Re: LS/VTEC 400HP on stock sleeves!!!, dyno graph inside (Boostfed)
Are you running a block guard?
Old Oct 4, 2004 | 01:35 PM
Casey's Avatar
awesome numbers...your boost is probably dropping due to the 9psi spring and/or the 2.25 dp...replace those and i bet your problems will be solved plus make a few extra hp
Old Oct 4, 2004 | 01:56 PM
darkdayz's Avatar
that's amazing.....good job with the ls/vtec
Old Oct 4, 2004 | 01:59 PM
Boostfed's Avatar
New User
Is the H23 dyno Derron's old set up?
Old Oct 4, 2004 | 02:18 PM
TwoPointZero's Avatar
Banned
Default Re: LS/VTEC 400HP on stock sleeves!!!, dyno graph inside (Casey)
Awesome numbers.. I have almost the exact setup that im building.. These are the numbers that im looking for.
Old Oct 4, 2004 | 02:41 PM
DRAGLS's Avatar
What kind of timing were you running?
Hector
Jdm93civic's Avatar
wow man those are some big torque numbers.......
Old Oct 4, 2004 | 04:16 PM
DLB1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">Is the H23 dyno Derron's old set up?</TD></TR></TABLE>
naw its a prelude i did with a stock drag , that i tuned up there first of the year
maxed out a stock drag kit with 21-22psi i think
