Tranny wont go into reverse
LAtely my tranny is having trouble going into reverse. It takes forever for it to finally go into it. Are they my syncros and with GM sincromesh fix this problem? THanks
all of the honda's i have driven do this... usually just put it into first gear, nuetral then try reverse, it should slip right into reverse just dont force it.. also like u said make sure there is some oil in the gear box
Happens to me all of the time on my LS transmission. When i say all of the time, i mean ALL OF THE TIME. It happens everyday at least
I just release the clutch, push it back in and then put it in reverse. That usually works. If it is being more stubborn I have to put it in first, then go to reverse.
Yup, and if you REALLY can't get it in reverse, just put it in first and drive 1 inch forward and try again. Also if you are on any kind of slop, just let the car SLIGHTLY roll while you are putting it in reverse. It should slip right...
yep, it's like that for most hondas that i've driven.....just press the clutch and release it and it should get into gear just fine...or u can just shift into 4th and then reverse..
haha I got the same problem clucth it like 2 or 3 times up and down then trow in reverse slow. It works for me or try going 1st, 2nd and the slow put reverse see what happens
mine does the same also. i go from 2nd to neutral and than to reverse. sumtimes if that dont work i just release my clutch and do the same steps and it pops in perfectly. yes ls have **** up tranny.
oh-k
Oct 7, 2004 06:41 PM
EdBoon
Apr 25, 2004 06:02 PM
