b20 turbo crx!
Old Dec 13, 2001 | 11:41 AM
Max_ED9's Avatar
Default b20 turbo crx!
i did a search, but not many things in specific that i was lookin for i found...
i got a couple questions about the b20b swap and turbo parts....
to begin with...
do any of you know any sites for a b20 swap to a crx???
here are the parts needed i think...
- b20b engine/ Ls tranny / Ls intake manifold
- hasport b series mounts
- maintenance items (belts, pumps, plugs,etc)
- wiring (same as a Ls swap wiring???)
- 90-93 teg axles if im using a ls tranny?
- what shift linkage?
- what throttle cable?
- anyhting else for the swap?
for the turbo:
just one question:
does the revhard b series fit the b20b in a crx in pipin modifiacations?
does the drag gen III???
Old Dec 13, 2001 | 11:48 AM
DR. ON POINT's Avatar
Banned
Default Re: b20 turbo crx! (maxracing)
do a search man
Old Dec 13, 2001 | 12:30 PM
One8Hatch's Avatar
New User
you should use the same distributer as the ecu, like a 91 teg non obd ecu and non obd teg distributer
Old Dec 13, 2001 | 08:38 PM
#417R's Avatar
Your list looks pretty good so far. I would probably go with a gsr tranny instead of a ls tranny. A friend of mine has had both trannys in his b20bturbo'd crx and he said he felt like the gsr tranny pulled better. You'll also need a 94-96 OBD1 ls ecu and distributor. As far as the turbo goes the b-series manifold will work but the intercooler piping will probably need to be shortened to accomadate the small engine compartment size on your crx. Good luck with the swap
Old Dec 13, 2001 | 08:59 PM
BigBlockCRX's Avatar
New User
as for sites with a crx.. dont know any
btw what the hell happened to your HF?
Old Dec 14, 2001 | 01:16 AM
Max_ED9's Avatar
Default Re: b20 turbo crx! (BigBlockCRX)
ahh... my beloved HF....
well to put it in simple terms....
the second day i bought it i was pulling out of a parking lot from a long day at work, and a ford explorer did a turn in the parking lot around 30mph and T-Boned me.... this was on the 17th of July of this year, and i am still awaiting word from my lawyer...
yes, the second day, it was totalled...so now it is sitting in my garage with all of my newly acquired Si interior parts (its gutted)...
as for the b20 swap... im saving up all of my money so i can do it around March.... and the turbo around summer.... then maybe pistons, rods, sleeves around next christmas... and a 12 second daily driver....
then maybe a vtec head sometime next year... but i got school to pay for right now... so a little at a time...
stpacura
Jan 2, 2006 07:08 AM
eatbieodie2
Oct 25, 2005 07:32 AM
AcCorD 9dfive
May 2, 2003 06:32 PM
Max_ED9
Dec 14, 2001 11:27 AM
