205/50-15 on stock rim questions
Old Dec 13, 2001 | 11:39 AM
neo1z's Avatar
Default 205/50-15 on stock rim questions
will there be any problems with running this size - i know alot of you do - but are there any offset or speedo problems with running the size? could you make me aware of all things i need to consider?
also - kumho ecstas are decent i gather, that was my plan.
Old Dec 13, 2001 | 12:06 PM
MrBite's Avatar
Default Re: 205/50-15 on stock rim questions (neo1z)
I'm pretty sure those are a little bit shorter than the stock tires, so yes your speedo/odo will be off a little.
Old Dec 13, 2001 | 12:09 PM
neo1z's Avatar
Default Re: 205/50-15 on stock rim questions (MrBite)
i talked to some guy at acura and he said that if the tires are the wrong size it will throw off everything including the speedo - like air/fuel ratios and everything like that...it all seemed shady to me, also said it screwed up the "syncros and stuff when helping match revs" - quoth mike at acura
Old Dec 13, 2001 | 12:42 PM
bocian's Avatar
mike doesnt have much of an idea what he's talking about. yea the speedo might be slightly off (id say at about 80 mph, it might be like 2 or 3 miles off, if that)
but let everyone here tell you, mostly everyone, including me, is running 205-50-15 and we all have no problems with it, it only helps.
right now i temporarily sqwitched back to 195-55-15 and the it feels like **** compared with 205's.
Old Dec 13, 2001 | 12:46 PM
GSRwBOOST's Avatar
Just had a set put on.. very nice, responsive... so waht if it's off a mph or two...
Old Dec 13, 2001 | 01:40 PM
Stephen's Avatar
Default Re: 205/50-15 on stock rim questions (GSRwBOOST)
you may be off a few mph on the speedo, but not much. The thing with the syncros and A/F ratios messing up is BS. The 205's have a 7.5mm smaller radius, which is nothing really.
One benefit is you will never scratch your rims on curbs again.
Old Dec 13, 2001 | 02:05 PM
G_S_R's Avatar
Default Re: 205/50-15 on stock rim questions (Stephen)
you should not have any problems. I ran that size of tires autoxing.
as far as speedo. it'll be off by about 2-4 mph. no biggie.
ron
Old Dec 13, 2001 | 03:23 PM
Def's Avatar
Def
Default Re: 205/50-15 on stock rim questions (G_S_R)
Your speedo will be off by 2.1 mph at 100mph. So at any normal driving speeds you won't be able to notice it.
This also means that you'll only add up 21 extra miles to your odometer every 1000 miles you actually travel. So 1000 mi actual = 1021 mi indicated.
Old Dec 13, 2001 | 03:36 PM
1fastGSR's Avatar
New User
perfect fit.
I saw a 98 ITR with 225/50/15 tires!!!!
Old Dec 13, 2001 | 04:32 PM
Kellindal's Avatar
As for your tire choice, Get Dunlop SP 8000 if you can spend the extra dollars. Much better tire IMO.
Old Dec 13, 2001 | 05:34 PM
stick's Avatar
Default Re: 205/50-15 on stock rim questions (Kellindal)
agreed
Old Dec 13, 2001 | 05:39 PM
neo1z's Avatar
Default Re: 205/50-15 on stock rim questions (stick)
yea i was looking at the dunlop's..... i have about a spending limit of 400$ for tires/balancing etc. - so i kinda want to stay within - w/ the kumho's ill be a bit under and i dont know how close ill be with the dunlops...what would u do
Old Dec 13, 2001 | 07:46 PM
ALF's Avatar
ALF
Save up a little extra money to get the better tire.
Old Dec 13, 2001 | 10:50 PM
MRXMUFFIN's Avatar
yeah getting 205/50/15s for your car is fine, i just had my kumhos same size as ur refering to put on last month and their fine. its amazing what some people at the dealership will say to make you think they know wassup.
Old Dec 13, 2001 | 11:58 PM
George H's Avatar
I'm running 205/50/15 and at 4k rpm in 5th gear i'm doing 78mph. I would suggest you get the Falken Azenis in that size. I believe it is a much better tire than the Kumho, and it runs about $60 each, which is a good price. As for my tires, I am running the Bridgestone Potenza RE730's and love them.
Old Dec 14, 2001 | 12:50 AM
Cramerox's Avatar
i dont think the speedo will get messed up. if you think about it, it works like a ration in physics. the odo counts the tire spin not from the engine. Plus i also heard that the 205 width makes up for the difference in tire height. Please someone correct me if im wrong?? I wondered this before and i hope someone credible can confirm this?
Old Dec 14, 2001 | 04:39 AM
AkiraLite's Avatar
Default Re: 205/50-15 on stock rim questions (Cramerox)
Hello All, transferred over from H-A.net, 1st post
This is from whalentire.com online tire selection
STOCK SIZE: 195/55R15
DIAMETER: 23.4" SECTION WIDTH: 7.7" SIDEWALL HEIGHT: 4.2"
REVOLUTIONS PER MILE: 861
SELECTED SIZE: 205/50R15
DIAMETER: 23.1" SECTION WIDTH: 8.1" SIDEWALL HEIGHT: 4.0"
REVOLUTIONS PER MILE: 875
IF YOU TRAVELED 60 MPH WITH THIS TIRE INSTALLED ON YOUR VEHICLE YOUR SPEEDOMETER WOULD READ 61.0 MPH
Old Dec 14, 2001 | 05:01 AM
MAGSGSR's Avatar
Default Re: 205/50-15 on stock rim questions (AkiraLite)
I can't imagine there being any issues,i run nitto 450 extremes 205/50/15 and the car handles great however theres a little more gap in the wheel well but nothing a little suspension can't fix.You can get nittos that are VR rated for around 65$ a piece plus mount and balance.And about another 7$ for road hazard in wich they will replace any tire thats unrepairable as long as it has 1/32 of an inch left on it.
Old Dec 14, 2001 | 05:13 AM
exquivical's Avatar
New User
hahhahahahahahah....throw off air to fuel ratios? baaaaaahahahahahhaha. I'm suprised you didn't laugh your *** off when he said that. I know a guy with a GSR thats been running 205/50s for years on years, it'll be fine.
Old Dec 14, 2001 | 05:35 AM
smeister's Avatar
I run that size without spacers and I don't rub anywhere. You will rub with 225s without spacers. I think most people would agree that the 205s are better for preformance than the 195s. HTH
Old Dec 14, 2001 | 10:27 AM
Slain's Avatar
Default Re: 205/50-15 on stock rim questions (smeister)
falken azenis are pretty good and are fairly cheap
Old Dec 14, 2001 | 07:42 PM
neo1z's Avatar
Default Re: 205/50-15 on stock rim questions (Slain)
i did chuckle when he mentioned air/fuel ratios - ive never heard of the azenis (ive heard of falken) - we think those are better than kumho ecstas?
Old Dec 15, 2001 | 07:42 AM
TurboSedan's Avatar
New User
Azenis are way better than Kumho for dry grip and traction. In the wet, uh.....no. For the money, in dry weather, the Azenis can't be beat.
Old Dec 15, 2001 | 09:10 AM
Phat Corolla's Avatar
New User
Default Re: 205/50-15 on stock rim questions (97CivicFerio)
Give this site a try:
http://www.miata.net/garage/tirecalc.html
It will tell you all you want to know about tire sizes.
Old Dec 15, 2001 | 09:12 AM
New User
Default Re: 205/50-15 on stock rim questions (Phat GS-R)
whoops...zeroforum takes out spaces...bummer.
[Modified by Phat GS-R, 10:13 AM 12/15/2001]
