...Professional Product Harmonic Damper...
Old Oct 2, 2004 | 12:10 PM
DDD's Avatar
DDD
Default ...Professional Product Harmonic Damper...
Has any one seen or used this product? ?
http://www.professional-products.com/
Professional Products offers an SFI Spec Powerforce+Plus damper for racing applications that fits B-16, Type R, and GSR Hondas. Also available are Powerforce High Performance Street dampers for B-16 and GSR. The GSR can be used on the Type R but the alternator will run 6% faster, the A/C 2% faster and the power steering will be 12% slower. The 90050 is made of tough 1045 steel and the 80051 and 80052 are made of stout nodular iron.
80051
Powerforce Street Damper for B-16 Honda
80052
Powerforce Street Damper for GSR
90050
Powerforce+Plus Race Damper for B-16,GSR,
Old Oct 2, 2004 | 12:47 PM
Pacman
Guest
Posts: n/a
Default Re: ...Professional Product Harmonic Damper... (DDD)
I seen it but in our race motor we us civic type r N1 pulley..
Old Oct 2, 2004 | 06:58 PM
red civic standard's Avatar
Default Re: ...Professional Product Harmonic Damper... (Pacman)
How much do they cost?
Is this piece supposed to make power over the stock one? or just make the engine more reliable?
Old Oct 2, 2004 | 11:23 PM
SkRiBLaH's Avatar
Default Re: ...Professional Product Harmonic Damper... (red civic standard)
its a lightweight pully with a dampener... if they have a good price then they should be a good investment.
you guys running unorthodox crank pully's and ctr n1's (AKA a pully with a dampener)... daily driving.. your going to fry your motor.
Old Oct 2, 2004 | 11:24 PM
JL's Avatar
JL
Default Re: ...Professional Product Harmonic Damper... (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">its a lightweight pully with a dampener... if they have a good price then they should be a good investment.
you guys running unorthodox crank pully's and ctr n1's (AKA a pully with a dampener)... daily driving.. your going to fry your motor.</TD></TR></TABLE>
i sure hope not.. let you know when its fried.
Old Oct 2, 2004 | 11:54 PM
WrongWD's Avatar
ive heard great things about those
Old Oct 3, 2004 | 12:06 AM
rjay8604's Avatar
Default Re: (WrongWD)
You guys ever wonder why honda just uses a solid metal pulley, no integrated dampener.
Old Oct 3, 2004 | 01:44 AM
wHOAlly's Avatar
Default Re: (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">You guys ever wonder why honda just uses a solid metal pulley, no integrated dampener.</TD></TR></TABLE>
i know that b serires with the exceptionl of the n1 pulley are all dampened, they all have a band of rubber that seperates the outter ribs from the center.
Old Oct 3, 2004 | 02:36 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n’d Supra &raquo;</TD></TR><TR><TD CLASS="quote">
i know that b serires with the exceptionl of the n1 pulley are all dampened, they all have a band of rubber that seperates the outter ribs from the center.</TD></TR></TABLE>
yup this is true..
Old Oct 3, 2004 | 08:51 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">Is this piece supposed to make power over the stock one?</TD></TR></TABLE>Pullys don't make power
Old Oct 3, 2004 | 08:54 AM
Rob Dizzle's Avatar
Default Re: ...Professional Product Harmonic Damper... (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Pullys don't make power</TD></TR></TABLE>
even if its lighter weight?
or you just stating different diameters dont make a change in hp?
Old Oct 3, 2004 | 09:33 AM
Pacman
Guest
Posts: n/a
you guys running unorthodox daily driving.. your going to fry your motor.</TD></TR></TABLE>
Damage maybe on the DOX but not the CTR N1
Old Oct 3, 2004 | 10:29 AM
631 Teggy's Avatar
Nope... They do however in some cases release power by reducing unsprung weight... That's why you see dyno gains... Doesn't endyn make a unit like this?
Old Oct 3, 2004 | 01:03 PM
earl's Avatar
Default Re: ...Professional Product Harmonic Damper... (631 Teggy)
Endyn sells the Fluidampr to help control crank harmonics.
A smaller pulley may cause less parasitic drain of hp but cannot make power.
Old Oct 3, 2004 | 06:35 PM
SkRiBLaH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pacman &raquo;</TD></TR><TR><TD CLASS="quote">
Damage maybe on the DOX but not the CTR N1</TD></TR></TABLE>
its the same basic thing... a pully with no dampener. solid.
Old Oct 3, 2004 | 07:40 PM
kur0ryu's Avatar
I thought this was true as my first B16A (jdm OBD0) had the injected rubber. But my JDM B16A SiR II engine had a different stock pulley, and externally I don't see any rubber. Actually, I had a machine shop remove the power steering portion off it, and still saw no rubber.
Old Oct 3, 2004 | 08:48 PM
SkRiBLaH's Avatar
Default Re: (kur0ryu)
(taken from http://m24x.zeroforum.com/zerothread?id=1244 )
this is a stock crank pully with AC and PS ribs removed... see the rubber?
Old Oct 3, 2004 | 11:39 PM
rjay8604's Avatar
Default Re: (SkRiBLaH)
Thats a stock crank pulley, but stock on what?
Old Oct 3, 2004 | 11:57 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu &raquo;</TD></TR><TR><TD CLASS="quote">
I thought this was true as my first B16A (jdm OBD0) had the injected rubber. But my JDM B16A SiR II engine had a different stock pulley, and externally I don't see any rubber. Actually, I had a machine shop remove the power steering portion off it, and still saw no rubber.</TD></TR></TABLE>
the 2nd gen b16 one i had definately had the rubber...a few d series dont have the rubber from what i remember.
after reading this...
http://www.fluidampr.com/torsional_vibration.htm
makes sense how the fluidampr works better than a standard rubber dampened pulley, atleast IMO.
think of a gyro
Old Oct 4, 2004 | 08:48 AM
bs-inc's Avatar
So back on topic. Does anyone have experience with these crank pulleys?
I have a chipped crank pulley and this seems like a good investment.
Old Oct 4, 2004 | 12:39 PM
rev limiter's Avatar
Default Re: (bs-inc)
i am about to have a b18c1 gsr bottom end build with knife-edged crank is it worth it to get a ctr N1 pulley or should i just stick with the stock crank pulley ??
Old Oct 4, 2004 | 05:36 PM
DDD's Avatar
DDD
Default Re: (rev limiter)
I talked to Professional Products today so I'll post some info soon .... I want to get tha facts straight 1st. The pieces are new, as in only been available for a few weeks, but they are avaiable for purchase now (so they said).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev limiter &raquo;</TD></TR><TR><TD CLASS="quote">i am about to have a b18c1 gsr bottom end build with knife-edged crank is it worth it to get a ctr N1 pulley or should i just stick with the stock crank pulley ??</TD></TR></TABLE>
I think you and many others may be interested in this product.
The 90050 Powerforce+Plus Race Damper for B-16,GSR, and Type R was said to be the same diameter as the CTR N1, is dampend ( CTR is not), and is SFI certified (CTR is not).
Like I said more info soon ... I need to talk to my local Professional Products distributer before I say any more.
Old Oct 4, 2004 | 11:51 PM
Default Re: (DDD)
any idea of the price ??
Outlaw-Hondaz
Apr 22, 2011 09:05 PM
4Dinsaneb16
14
Jan 25, 2007 02:55 PM
jdmoutlaw
Jan 10, 2004 04:34 PM
