92' civic hatch manifold swap problems
Old Oct 2, 2004 | 11:42 AM
snatchbakman's Avatar
Default 92' civic hatch manifold swap problems
we decided to swap my tiny manifold with and larger one off a d15 90 si. i still have my stock motor. we hooked everything up the same, go to start it and RPMs just jump with out touching the gas gas. i was told it might be a throttle gaskets or the manifold gasket. what eles could it be ???
Old Oct 2, 2004 | 11:58 AM
mntuner2's Avatar
Default Re: 92' civic hatch manifold swap problems (snatchbakman)
Anything that can let air into the manifold when the throttle blade is closed. Go find the crossed wires or vacuum leak.
Not enough information to accurately diagnose. What model do you have, what EXACTLY has been done to the wiring and intake tract. DPFI to MPFI?? Upgrading and HF throttle body??
Old Nov 16, 2004 | 06:32 PM
Go Fast Civic's Avatar
Default Re: 92' civic hatch manifold swap problems (mntuner2)
throttle cable
Old Nov 16, 2004 | 06:41 PM
dx2sicrx's Avatar
it is the throttle position sensor on the old school the two outers need to be switched other wise the ecu thinks it is at wide open throttle. try it out and let me know.
Old Nov 16, 2004 | 06:43 PM
dx2sicrx's Avatar
as for old I mean 88-91 and if you are putting it on a 92 it goes as i said
Old Nov 16, 2004 | 06:51 PM
dr_latino999's Avatar
Default Re: (dx2sicrx)
What motor?
integrainside
10
Apr 29, 2008 11:50 AM
citystars41
Jan 10, 2008 09:58 PM
92 CIVIC HATCH VX
Jun 12, 2007 11:06 AM
JforJonathan
10
Apr 10, 2004 12:15 PM
