Skunk2 stage 2 compression craving?
Old Oct 2, 2004 | 10:07 AM
JFG Kevin's Avatar
Default Skunk2 stage 2 compression craving?
How much do you guys think stage 2 needs as in compression. I have a gsr and was thinking of going ctr pistin. Do you guys think that'll bump enough with a mill head?
Old Oct 2, 2004 | 10:25 AM
fuck honda-tech's Avatar
Default Re: Skunk2 stage 2 compression craving? (aznstyler119)
ya thats enought compression, try searching usually. 11.5 and up compression is good. those ctrs in a gsr will be around 12.0 +
Old Oct 2, 2004 | 10:30 AM
jdmHboy's Avatar
Default Re: Skunk2 stage 2 compression craving? (DankgsR)
12:1 cr would be perfect for those cams. I wouldn't mill the head either.
Old Oct 2, 2004 | 01:05 PM
Runnerdown's Avatar
Don't run ctr or mill the head the compression will be way to high.
Old Oct 2, 2004 | 02:55 PM
jdmHboy's Avatar
Default Re: (Runnerdown)
The sweet spot compression wise for those cams is around 11.8:1 if u use a dynamic compression ratio calculator (correct me if im wrong), so 12:1 isn't really too much.
Old Oct 2, 2004 | 05:37 PM
AllMotorGSR94's Avatar
im running 12:1 with my stage 2s and they love it....
Old Oct 2, 2004 | 06:24 PM
Runnerdown's Avatar
ctr in a gsr is more like 13:1.
Old Oct 2, 2004 | 06:42 PM
zad5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">ctr in a gsr is more like 13:1.</TD></TR></TABLE>
you sure.... i always that on a gs-r head it would be at 12.1 or so.
Old Oct 2, 2004 | 07:00 PM
Runnerdown's Avatar
https://honda-tech.com/zerothread?id=717928
P72 head/B18C Block
STD = 12.924594026551906
.25 OS = 12.989047869209281
Old Oct 2, 2004 | 08:28 PM
jdmHboy's Avatar
If you use a compression ratio calculator such as the one on http://www.c-speedracing.com, the cr is around 12:1.
Old Oct 3, 2004 | 06:19 AM
Runnerdown's Avatar
C-speeds compression calculator is incorrect in regards to PCT pistons! See the above link ^^^^
Old Oct 3, 2004 | 09:36 AM
Pacman
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Don't run ctr or mill the head the compression will be way to high.</TD></TR></TABLE>
Nothing is too high...
Old Oct 3, 2004 | 05:39 PM
JFG Kevin's Avatar
Default Re: (Pacman)
CTR sounds good to me. thx for the replies.
Old Oct 3, 2004 | 11:19 PM
JFG Kevin's Avatar
Default Re: (aznstyler119)
bump...does anyone know exactly how much CTR bump compresstion for gsr?
Old Oct 4, 2004 | 03:14 AM
Runnerdown's Avatar
Yes, did you see this post at all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=717928
P72 head/B18C Block
Old Oct 4, 2004 | 05:38 AM
hype r 555's Avatar
I'm running 12.5:1 and my s2stg2's love it
Old Aug 18, 2006 | 03:06 PM
JFG Kevin's Avatar
Default Re: (hype r 555)
Welp a year later with the CTR piston in my motor it BLEW....It loved the 13.1 compression for about a year and it gave me the MIDDLE FINGER....haha...I was now thinking about using PR3 pistons where my compression should be at 11.28, or should i get p30 to bump it up to 11.5. I'm also planning to hit the nitrous button eventually. So i'm leaning toward the PR3 for lower compresson safer for Nitrous..Whats your thoughts on that?
Old Aug 18, 2006 | 03:43 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">Welp a year later with the CTR piston in my motor it BLEW....It loved the 13.1 compression for about a year and it gave me the MIDDLE FINGER....haha...I was now thinking about using PR3 pistons where my compression should be at 11.28, or should i get p30 to bump it up to 11.5. I'm also planning to hit the nitrous button eventually. So i'm leaning toward the PR3 for lower compresson safer for Nitrous..Whats your thoughts on that?</TD></TR></TABLE> Hey, I would go 13-1 this poster made it a year. Wo-Ho. I have block's and heads for sale. 13.4-1 sounds like a good number. IM me for parts. After the button.
Old Aug 18, 2006 | 04:05 PM
UncleD's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> IM me for parts. After the button.</TD></TR></TABLE>
Mhollaek9
20
Aug 17, 2007 01:08 PM
pydc2r
May 29, 2007 09:33 AM
GSR in Progress
Jan 10, 2006 06:37 PM
JDMlyfestyle
11
Feb 16, 2005 01:36 PM
Slow96RedEk
Nov 17, 2003 08:36 AM
