HELP fuel rail, fpr, and fuel pressure gauge install
Old Oct 2, 2004 | 10:05 AM
cvc323's Avatar
Default HELP fuel rail, fpr, and fuel pressure gauge install
I just installed an STR fuel rail and a B&M regulater. Everything went smoothly but the gauge isn't reading anything. I installed the gauge onto the fuel rail but its not putting out any readings. Any suggestions?
Old Oct 2, 2004 | 10:53 AM
cvc323's Avatar
Default Re: HELP fuel rail, fpr, and fuel pressure gauge install (cvc323)
I just tried installing the gauge directly on the fuel filter and it started to work, but the gauge is reading 70 psi and when I give it gas it starts moving down toward 60 psi. Has anyone had this same problem???
Old Oct 2, 2004 | 01:32 PM
cvc323's Avatar
ttt
Old Oct 27, 2004 | 06:43 AM
RNPoo7's Avatar
anyone? i would like to know.
Old Oct 27, 2004 | 08:19 AM
AgentJam's Avatar
sounds like something is seriously wrong with the regulator or gauge. The pressure should raise as you open throttle body and less vacuum is present.
Try using a different gauge to see if it becomes normal...hopefully it's just the gauge?
Vince
Old Oct 27, 2004 | 08:41 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: HELP fuel rail, fpr, and fuel pressure gauge install (AgentJam)
I have heard of people having trouble
with the B&M fuel pressure gauge due to it
being somewhat fragile...
[I myself have one and have not had any problems..]
From what I understand,
Most likely the damage was from not using a 7/16"wrench on the brass
portion underneath the gauge and instead tightening it using the gauge housing..
If you bleed the pressure off and the gauge does not go to ZERO..
most likely then it is defective..
Old Oct 27, 2004 | 09:01 AM
RNPoo7's Avatar
so do you prefer autometer over B&M when it comes to gauges?
acmoc
Engine Management and Tuning
Apr 19, 2011 08:27 AM
irishflame27
Dec 14, 2008 07:55 PM
RacinMasonC
Feb 11, 2008 09:44 PM
spidermancivic
Feb 23, 2005 09:48 AM
