1994 h22a rotora nad distributor
Old Oct 2, 2004 | 08:13 AM
mayfieldfour's Avatar
Default 1994 h22a rotora nad distributor
I have been doing some general maintenance on my Acclude while it is down (bad oil pressure problem...found a bad oil pump and working on replacing that now. HHOPEFULLY that is it!), and I am trying to replace the rotor on my h22a distributor (its a 94 motor). I bought a new rotor from Majestic Honda and went to replace it last night based on the service manuals listings. Well, it doesn't seem to replace the same as the USDM. The little bolt that holds the USDM rotor in does NOT exist on the JDM rotor. Does anyone know how to replace just the rotor of a jdm h22a distributor? I tried simply pulling it off and that didn't work. I have done a couple searches, both on here and yahoo, and found nothing as well.
On sort of the same note, does anyone know where to find a dealer service manual for the h22a? I bought a USDM service manual, but I am slowing finding some differences in the way to repair things on the USDM and the JDM versions.
Old Oct 2, 2004 | 12:09 PM
soon2b's Avatar
Default Re: 1994 h22a rotora nad distributor (mayfieldfour)
Not to be a *** but the set screw is still there on the jdm h22. Have u tried turning the motor over and lookin for the screw its there trust me.
Old Oct 2, 2004 | 12:35 PM
yohan's Avatar
Yup, if you look at the new rotor, threse a hole where the screw goes ... pull off the dizzy cap and turn the key in the ignition, you can barely see the rotor turning from inside the car so just give it a rotate until the contact edge is facing the firewall
MKCSRet
Aug 7, 2014 06:40 AM
ketchup
Apr 8, 2008 08:16 PM
redtech
Mar 6, 2006 08:34 PM
monalisa overdrive
Jun 10, 2005 11:13 PM
