Control Arms? Replace or new bushings?
Old Oct 2, 2004 | 06:51 AM
Castle228's Avatar
Default Control Arms? Replace or new bushings?
Hey everyone! This is my first post on here....so whassssssup!!
I have a '91 CRX SI, exhaust, intake, upper stress bar, Tokico/Eibach suspension and I have a question about the control arms. Will I be okay by just replacing all the bushings in all the control arms or do I need to replace the actual arms themselves?
My thought is that I will be fine with some Poly bushings but wanted to get some opinions.
Thoughts and comments are welcomed. THANKS!
Old Oct 2, 2004 | 06:54 AM
crxgator's Avatar
Default Re: Control Arms? Replace or new bushings? (Castle228)
you can replace the bushings...
since i wanted oem honda bushings, i just bought the new control arms for 120 for the pair for the rear...saves time and work...
Old Oct 2, 2004 | 06:57 AM
Castle228's Avatar
Default Re: Control Arms? Replace or new bushings? (crxgator)
OEM Honda bushings? Those are rubber, no? You prefer rubber over Poly? Any specific reason?
Old Oct 2, 2004 | 07:09 AM
crxgator's Avatar
i wanted less harsh of a ride, plus i didnt want squeeks...
Old Oct 2, 2004 | 07:21 AM
Castle228's Avatar
Hmmmm. Now you got me thinking. Does all Poly squeak and does it make the ride that rigid? I don't think I'd mind the stiff ride, but they squeaking might be annoying....
thanks for the input....
Old Oct 2, 2004 | 07:25 AM
crxgator's Avatar
well it has to be lube beforehand, but man i hear some peoples cars, and its bad, squeek squeek squeek all day...
Old Oct 2, 2004 | 07:39 AM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">well it has to be lube beforehand, but man i hear some peoples cars, and its bad, squeek squeek squeek all day... </TD></TR></TABLE>
Lots of lube is very important! You can control the squeak but the ride is firmer/harsher or...well.....different. I've had poly for two years and no squeak.
HTH
chris
Old Oct 2, 2004 | 08:01 AM
Castle228's Avatar
Default Re: Control Arms? Replace or new bushings? (NCchris)
NCchris, poly for 2 years with no squeak and lubed? how often do you lube the bushings? is this something you can do without putting the car on a lift? what type of lube do you use? how difficult is it to lube the bushings?
i know i'm asking alot of questions but this is kind of a new area for me....thanks for the help.
Old Oct 2, 2004 | 08:06 AM
I3ackfire's Avatar
I know that alot of guys here on HT go with the the OEM honda bushings, or the Mugen rubber bushings. I remember there was a thread on this a while back, do a search for it, all the questions you have will be answered there
Old Oct 2, 2004 | 09:24 AM
DocSean's Avatar
Default Re: Control Arms? Replace or new bushings? (I3ackfire)
Correct me if I'm wrong, but don't the type R lower contol arms fit on the crx...or was that the EG chassis??? I'm assuming this would be an improvement?
Old Oct 2, 2004 | 06:03 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Castle228 &raquo;</TD></TR><TR><TD CLASS="quote">NCchris, poly for 2 years with no squeak and lubed? how often do you lube the bushings? is this something you can do without putting the car on a lift? what type of lube do you use? how difficult is it to lube the bushings?
I have not lubed them since install. The prothane bushings I used came with lube and I used all of it. This stuff works well too
HTH
chris
Mentat Ghola
Suspension & Brakes
Nov 8, 2011 09:18 AM
Furious Styles
Apr 26, 2011 02:16 PM
sshiny007
20
Oct 28, 2009 06:49 AM
blackccoupe
May 16, 2008 07:21 PM
