Transmission is about to go ... I think.
Old Dec 13, 2001 | 10:24 AM
Hamil's Avatar
New User
Default Transmission is about to go ... I think.
I have a 95 accord ex vtec coupe.
My transmission is shifting a little bit harder as of late. It generally is only noticable when I am accellerating slowly (not often) and it has 125k miles on it. Should I prepare to buy one now? I can get about $500 by trading in some stock options of mine. I have heard that I can get a used JDM trany for about that much... is that accurate or a bad idea. The fluid is fine (already checked). Any input would be appreciated and any estimates on transmissions would be nice as well.
While I'm here .... what rims would look best on my car?
J/K
Old Dec 13, 2001 | 10:37 AM
urbanlegend21's Avatar
New User
Default Re: Transmission is about to go ... I think. (atshaccord)
your synchros may be going,transmissions are generally expensive as a whole
Kosei K1's for wheels, 15" to keep a performance aspect
Old Dec 13, 2001 | 11:15 AM
Hamil's Avatar
New User
Default Re: Transmission is about to go ... I think. (urbanlegend21)
your synchros
I have only a vaigue idea of what that is... I am kinda concerned ... think that will be more than $500?
Old Dec 13, 2001 | 12:19 PM
Hamil's Avatar
New User
one more possible help: when I am in D3 it doesn't seem to be as noticable.
Old Dec 13, 2001 | 12:20 PM
ForcedAccord's Avatar
Texas B*tch!
Like when you step on it it feels like it doesn't grip, then it kicks in?
Old Dec 13, 2001 | 12:35 PM
Hamil's Avatar
New User
Default Re: Transmission is about to go ... I think. (ForcedAccord)
I forgot to specify I have an automatic.
There is no "slipage" when I get on it. I can just feel it shift when I accellerate slowly. It doesn't "buck" but if it was a bit harder I could say it was bucking.
Old Dec 13, 2001 | 12:49 PM
4doorH22's Avatar
Is actually during shifting or is it when the lockup clutch engages? My mom's '90 Civic EX auto is clunking pretty bad on upshifts. I've never held Honda autos in high esteem. We're just gonna drive it until it dies.
Old Dec 13, 2001 | 12:57 PM
Hamil's Avatar
New User
Default Re: Transmission is about to go ... I think. (4doorH22)
Don't let my post count fool you I am a car retard. I think it's both up and downshifting when the problem occours.
Old Dec 13, 2001 | 01:02 PM
New User
check your transmission mounts and motor mounts
are Honda automatucs run with a driveband?
Old Dec 13, 2001 | 01:17 PM
Hamil's Avatar
New User
I'll get it checked out. Thanks...
Driveband? I found this illustration and I still don't get it
Old Dec 13, 2001 | 01:35 PM
crux131's Avatar
Call Don......he might be able to help you.
When was the last time you had it serviced ?( new filter, fluid.....basic auto transmission maintenance )
[Modified by crux131, 4:36 PM 12/13/2001]
Old Dec 13, 2001 | 01:49 PM
Hamil's Avatar
New User
Default Re: Transmission is about to go ... I think. (crux131)
I will
Last week. No change.
Old Dec 13, 2001 | 06:19 PM
Gennady's Avatar
New User
Welcome to Honda auto transmission.
BTW, you cannot change the filter on a honda auto. You can only change the fluid. Thats what I was told.
Old Dec 21, 2001 | 04:57 PM
HBCthugg's Avatar
Honda Auto transmissions suck. I have a 94 accord lx and I just went through my second transmission in two months. I bought a used one and it gave out in only two months.
Old Dec 22, 2001 | 10:56 AM
supadupamikey's Avatar
Default Re: Transmission is about to go ... I think. (Wont be beat)
FWIW, I had a 94 Civic EX automatic and there was no filter, only a magnetic drain plug.
Old Dec 22, 2001 | 11:15 AM
4doorRS5spd's Avatar
New User
Default Re: Transmission is about to go ... I think. (lilmikey77)
The 5th gen accord auto trannies shift really rough anyway. Are you using genuine Honda ATF, or are you just using the Dexron II stuff. That can make a difference.
If your tranny does go, I would suggest that you rebuild the tranny you have. This will be more reliable than buying a used tranny, even though it will cost more.
SPIKE'S91CIVICSI
13
Jul 14, 2011 07:30 PM
littledude56
Dec 30, 2008 01:02 AM
mach51
Honda Civic (2001 - 2005)
Apr 10, 2007 08:23 PM
kptrk6
Dec 27, 2005 05:16 PM
idragen
Aug 19, 2004 06:01 PM
