leaking MAD tranny fluid YO!
my tranny has taken a dump lately. and whats weird. it happend ALL of a sudden. not like grinding gears, or anything progessivly worsing. ANYWAYS. I get under there today, and see theres Tranny fluid dripping out of the Tranny, but where the clutch and flywheel would be. If what im thinkin the clutch blew, maybe one of the PP fingers put a hole. or the seal for the output shaft on the tranny blew, along with the bearing. what do you think guys???
I don't think you would be able to shift at all with the list of possibles you have just presented us with. How about a seal has just sprung a leak? The only way to find out is if you take the tranny off and give it a look.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI »</TD></TR><TR><TD CLASS="quote">my tranny has taken a dump lately. and whats weird. it happend ALL of a sudden. not like grinding gears, or anything progessivly worsing. ANYWAYS. I get under there today, and see theres Tranny fluid dripping out of the Tranny, but where the clutch and flywheel would be. If what im thinkin the clutch blew, maybe one of the PP fingers put a hole. or the seal for the output shaft on the tranny blew, along with the bearing. what do you think guys???</TD></TR></TABLE>
you sure its tranny oil and not engine oil? check your tranny fluid level...if its ok, then you might be leaking engine oil from the rear main seal cuz thats right behind the flywheel.
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI »</TD></TR><TR><TD CLASS="quote">^ did it cause crap shifting????</TD></TR></TABLE>
if the tranny loses its fluid.. its not going to shift so hot
Themouse
Nov 22, 2006 05:10 PM
Lei Siew Long
Sep 17, 2001 01:50 PM
