How do JUNIIIs idle?
Old Dec 13, 2001 | 10:20 AM
HX_Guy's Avatar
Default How do JUNIIIs idle?
Im looking to get a much better idle in my car (therefore going VTEC) bt still would like to make some good power. Id like as close to stock idle as possible. Are JUN111s to wild for this?
BTW: Compression would be 12:1 if that matters.
Old Dec 13, 2001 | 10:27 AM
JUNpoweredITR's Avatar
New User
Default Re: How do JUNIIIs idle? (HX_Guy)
I wouldn't use the term smooth with the JUN 3s. It's fairly rough. People can tell that I'm running big cams from the sound. I never tried the JUN 2s or 1s. 100% happy with it tho.
Peace...
[Modified by JUNpoweredITR, 7:27 PM 12/13/2001]
Old Dec 13, 2001 | 10:28 AM
HX_Guy's Avatar
Default Re: How do JUNIIIs idle? (JUNpoweredITR)
Damn...sounds a little too rough. I want stock like..very very quiet. Any suggestions?
Old Dec 13, 2001 | 10:30 AM
New User
Can't really recomend you to anything other than stock ITR, since that's the only cams I have prior experience with.
Peace...
[Modified by JUNpoweredITR, 7:30 PM 12/13/2001]
Black R's Avatar
25 Year Member
Why? There are trade-offs with any power adder...
Type 3's idle is mild compared to the spec b or c setups I've heard. Hell, I'm running spec b's and my idle is almost like stock. The sound is a function of your intake and exhaust setup. Quiet those down if you're worried about being given away... Or just say you ignition needs some work (bad plugs, wires, etc...)
Old Dec 13, 2001 | 10:33 AM
HX_Guy's Avatar
Default Re: How do JUNIIIs idle? (Black R)
As long as they dont sound like this...
http://pages.sssnet.com/mikey/lopingb20.mov
Old Dec 13, 2001 | 10:36 AM
IntegraT's Avatar
Spoons Idle stock IM me about gb if interested.
Old Dec 13, 2001 | 10:54 AM
kitkatR's Avatar
Default Re: How do JUNIIIs idle? (IntegraT)
My JUN 3's idle stock you can not even tell I have cams
Old Dec 13, 2001 | 10:56 AM
Cheap Bastard's Avatar
New User
My car idles like stock too. But it's a B16.
CB
Old Dec 13, 2001 | 11:57 AM
Black R's Avatar
25 Year Member
****. I'd have to run open header to sound like that!
Find someone local to you with type 3's and take a ride with them. You really have to know what to listen for to detect them at idle...
With a b20 setup, type 3's would be badass!
Old Dec 13, 2001 | 12:04 PM
HX_Guy's Avatar
Yea Id guess around 215 WHP
Mike K's Avatar
All the JUN cams idle like stock, so do Skunk2.
Good choices, all of them.
Old Dec 13, 2001 | 12:06 PM
HX_Guy's Avatar
Default Re: How do JUNIIIs idle? (Mike K)
Mike: Would you go for the JUN or Skunk2 cams? Also, what valvetrain?
Old Dec 13, 2001 | 12:15 PM
IntegraT's Avatar
Sorry not Mike but JUN...and...JUN
[Modified by IntegraT, 9:16 PM 12/13/2001]
Old Dec 13, 2001 | 12:19 PM
Black R's Avatar
25 Year Member
I'm betting ~220whp+
But the high-revving nature of the type 3's could be detrimental to the poor rod/ stroke ratio of the b20vtec...
Old Dec 13, 2001 | 12:23 PM
Johnny Tran's Avatar
Clearance issues? (piston/valve contact)
Old Dec 13, 2001 | 12:25 PM
Mike K's Avatar
Default Re: How do JUNIIIs idle? (Blue-POS)
The Jun3 cams are an excellent choice. As far as clearance is concerned, I went as far as +5 on the intake cam, and as much as -4 on the exhaust cam.. but not as the same time. LOL. The head was milled 20 thousandths and they were Endyn pistons. No contact.
Best results were seen at -1 intake cam, +2 exhaust cam.
HX_Guy's Avatar
No, with the Endyn pistons I think there is plenty of clerance. Hell I might even clay the clearance.
Good thing I got a girdle since these rev so high.
delSolLS's Avatar
Val
Is your idle worse since your rebuild? Have you changed cam timing since you put it back to 0, 0?
I have 62404's already on order for my B18B rebuild and just wondered if you had changed your mind on these cams.
Old Dec 13, 2001 | 12:27 PM
HX_Guy's Avatar
Default Re: How do JUNIIIs idle? (delSolLS)
I havnt retuned them yet, the cam gears are still at +4,-4. It didnt seem like the rebuild changed the idle.
Old Dec 13, 2001 | 12:33 PM
cool! i was just concerned because of your b20 setup......good luck
<------who wishes his POS had jun cams
Old Dec 13, 2001 | 12:42 PM
AllMotorMadness's Avatar
jun's cams have stock idle......
Old Dec 13, 2001 | 01:44 PM
non-VTEC's Avatar
+4 and -4...........damn...........no wonder your have a horible idle and your running very very VERY rich.......you just incresed the already to much overlap by ALOT more...........
put it to 0 and 0 and it should idle and smell a little better...........
Old Dec 13, 2001 | 01:47 PM
HX_Guy's Avatar
Default Re: How do JUNIIIs idle? (non-VTEC)
Yea but Il also lose the 8 HP adn 10 FT LBS I gained by tuning teh cams the way they are
skags
May 26, 2014 01:08 PM
redDAinteg
Jul 15, 2005 03:44 PM
my ride
Jul 3, 2004 01:55 AM
Montreal R
Apr 2, 2002 10:47 PM
itr501
Sep 27, 2001 04:01 PM
