Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
why does my rear brakes lock up before my front?
Old Oct 1, 2004 | 09:07 PM
racekar's Avatar
Default why does my rear brakes lock up before my front?
i went tracking tonday i have a 1994 civic cx
my rear drum brakes lock up before my front ones is there anyway to fix this?? is this common?
Old Oct 1, 2004 | 09:58 PM
prkiller's Avatar
Default Re: why does my rear brakes lock up before my front? (dchung1)
Need more info. Is that while straight line braking, or trail braking? When is the lock up occuring? Which track and what turn?
Old Oct 2, 2004 | 05:06 AM
Xian's Avatar
Default Re: why does my rear brakes lock up before my front? (prkiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller &raquo;</TD></TR><TR><TD CLASS="quote">Need more info. </TD></TR></TABLE>
What sort of front brakes are you running? Pad compound front vs. rear? Any front tire size or compound bias?
Old Oct 2, 2004 | 06:01 AM
Catch 22's Avatar
Default Re: why does my rear brakes lock up before my front? (Xian)
Under braking in a straight line or trailbraking, the rears get much lighter than the fronts and will tend to lock up first if you don't have a good compound balance.
Your rear shoes are either too good or your front pads are too crappy.
Or maybe your rears are out of adjustment.
Or maybe you had better tires on the front than you did on the rear.
Old Oct 2, 2004 | 06:20 AM
Safir's Avatar
Default Re: why does my rear brakes lock up before my front? (Catch 22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Catch 22 &raquo;</TD></TR><TR><TD CLASS="quote">Or maybe your rears are out of adjustment..
this is my guess.. poorly adjusted rear drums.
Old Oct 2, 2004 | 07:04 AM
racekar's Avatar
ok this is at button willow track
94 cx stock rear drums. and hp+ in front on stock rotors during straight line breakiing. the rear driver said it was locking up on the long straing 100 to 60
if it is out of adjustment how do i fix that? i ve done disc brakes but i assume drums are easier. thanks
also
i have ground control/koni setup, i dont know if it matters but 550 front, 750 rear spring rate
with toyo ra-1 tires
thanks
im pretty sure its straight line with a little trailbreaking
Old Oct 2, 2004 | 11:25 AM
Crazydave's Avatar
Default Re: (dchung1)
"1994 civic cx hatch, Ground control/kon yellow, 550/750 spring rate, rota slip, toyo ra-1 tires. b16 SIRII . Fully gutted "
put the back seat back in
Old Oct 2, 2004 | 04:04 PM
civicrr's Avatar
Default Re: (Crazydave)
using stock rear shoes?
get more pad for up front. your RA-1's can handle a lot more.
Old Oct 2, 2004 | 04:55 PM
Xian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dchung1 &raquo;</TD></TR><TR><TD CLASS="quote"> the rear driver said it was locking up on the long straing</TD></TR></TABLE>
So the driver behind you noticed the brake lockup but you (the driver) didn't? Is it possible that as you enter the corner and unload the inside tire, that you're getting a little rear tire smoke? Just seems kinda odd that you'd be locking the rears and not notice it from the driver seat...
Per someone else's advice, I'd also look into getting some more aggressive front pads.
Old Oct 2, 2004 | 05:40 PM
mantic6t9's Avatar
Default Re: (Xian)
I noticed this on my si hatch with 4 wheel disk brakes. I has some cheap AutoZone pads on the rear and Ultimates on the front. Hard stops (slam on brakes) in a straight line would always result in rear lockup. I think it's a combination of lack of weight in the rear of these cars exaggerated by the sudden weight transfer of quick and hard brakeing.
Old Oct 2, 2004 | 09:04 PM
racekar's Avatar
it didnt feel like it locked up.. and he said it did it real quick.. but i think thats prob it all the weight trasnferred to front no weight in back the rear breaks just lock up.
just wondering what others are doing to resolve this issue. ive seen this on others hondas. when my hp+ run out ill go with hp blue pads.
emooheo
Aug 20, 2007 07:21 PM
SinseidProbeGT
Sep 14, 2005 12:52 PM
EGlovr
Honda Motorcycles
16
May 4, 2005 08:49 PM
Boostage
Jan 2, 2005 08:44 PM
EH3_Si
52
Jul 20, 2003 07:21 AM
