How to wire EF so Front Signal Blinker light is constant
i've searched and searched and searched...i wanted to do this ghettojdm mod but i couldn't find anything on how to do it.
basically i wanted to hook it up so i could use an on/off switch to make my front bumper / blinker / signal lights remain on (when the switch is on) but to still blink when i signal.. i'm sure you've seen this before..
thanks for any help
thanks for any help
http://crxresource.org/modules...id=27
Here's how to make your bumper lights just stay on and use your corner lights for turn signals. I did it and it works pretty nice. The only drawback as stated in the article, is that your new turn signals will blink at 2X speed.
I did this mod by getting 2 corner light scockets from a 98 civic,with as much wire attached as possible,about a foot as I remember.The factory bumper sockets have 2 wires,green and black.The replacment corner sockets have 3 wires,green,black and red.Remove factory wire loom ,and at point where wires split,(you'll see what I mean when you get bumper off)About a foot up from socket,cut the green and black wires,strip about 1/2" on socket wires and factory wires and solder/heat shrink ,or you can getto it and use butt connectors or twist together and cover in electrical tape. I soldered mine.You will then see green,red,black wires going to the corner lights.Cut the red wire,again as close to where the wires split out of the bundle as possible and,strip,solder,heatshrink as with the green and black wires.Replace factory wire loom as it was before you started,repeat everything on other side.Now your bumper lights will burn as parking lights,and blink as turn signals.
tinhquaygot4ever
Dec 20, 2001 06:19 AM
i am liking this i just may have to do it
