1500 rpm rattle
Old Oct 1, 2004 | 02:56 PM
andrew-0's Avatar
Default 1500 rpm rattle
Hey, i own a 99 integra ls, with 65000 kms on it 5 spd,, and i got this weird rattle only at 1500 rpm. It sounds like its coming from the bottom of the car, maybe something in the exhaust piping, but the car has been doing it since when i got it stock, its annoying noice that sounds like some little thin peace of metal is hitting something. Any suggestions? Anyone has had this before?
thanks, Andrew.
Old Oct 1, 2004 | 03:14 PM
MotegiGSR's Avatar
Default Re: 1500 rpm rattle (andrew-0)
I have a 2001 GSR now and I used to have a 95 LS and I used to get the very same rattle that you are experiencing. Definitely something in the exhaust, possibly heat shield. Could never find the problem when i did look for what was rattling.
Old Oct 1, 2004 | 03:15 PM
AlxSiR7's Avatar
try searching on this subject... there are tons of threads about exhaust rattles (heat shields, pebbles, lose bolts), rotor shields, flywheel, etc....
Old Oct 1, 2004 | 03:31 PM
Brian_TII's Avatar
Don't forget to check you cat either... mine did that when it was falling apart / missing.
Old Oct 1, 2004 | 05:54 PM
andrew-0's Avatar
it aint catalyst, cause ive taken it off and then put it back... still rattled without it
Maybe i should just get a new catback system 2.5"
Old Oct 1, 2004 | 06:01 PM
53JDMDC2's Avatar
most of the time its the heat shields
Old Oct 1, 2004 | 06:04 PM
andrew-0's Avatar
So i shouldnt be worried about that? nothing serious? or does it affect something badly? except for my ears ^o)
Old Oct 1, 2004 | 08:22 PM
53JDMDC2's Avatar
Default Re: (andrew-0)
nothing to worry about as for your car.
Old Oct 1, 2004 | 08:38 PM
ITRiWISH's Avatar
mine dose the same thing at about 4k... on mine the area around the bolts that holt the heat shield to the top of the cat rusted through. so now the cat rattles. I am just about ready to cut it off! saws all... cutting wheel... C4... what ever it takes!!!
jcid07
May 27, 2010 10:37 PM
goodtrouble
Sep 6, 2007 08:40 AM
wegotmorrison
Aug 3, 2007 07:18 PM
j_hartwell
Aug 1, 2003 10:28 AM
Ben-VTEC
Mar 30, 2003 08:34 PM
