LS/VTEC Dyno, what should i do next?
Old Oct 1, 2004 | 02:33 PM
Shane54's Avatar
Default LS/VTEC Dyno, what should i do next?
Mods: ITR Pistons .50 over, ITR Cams('01), ITR Valve springs & retainers, AEM Cam gears, AEM Short Ram intake, DC 4-1 Header, DC Cat-back exhaust, Hondata Stage 2 with P28 ECU, ARP head studs, test pipe.
The first one was with the catalytic converter and i had a dip in the torque curve, and the second with a test pipe and a little tuning.
I was told that my injectors are running almost at full capacity, what kind of injectors are other people running(feedback please)
I was also thinking about going with an ITR intake manifold and throttle body, any other suggestions?
TIA
Old Oct 1, 2004 | 05:18 PM
sir91's Avatar
Default Re: LS/VTEC Dyno, what should i do next? (Shane54)
I suggest RC 270 injectors unless you are thinking of going bigger pistons anytime soon.
I also suggest a BBK fuel pump and if you don;t have one a fuel regulator.
I would go Skunk 2 Manifold instead of ITR and get a 68 or 70mm throttle body and have it match ported to the manifold.
With the right tuning this should get 10-15HP imo.
Old Oct 1, 2004 | 05:20 PM
95VXB16A's Avatar
Not bad #'s for the seutp u got there, for fuel get some rc 310's will be fine. If u want more power u will need a bigger TB, Intake Manifold, 2.5 in Header, 2.5 exhuast system , CAI. With this done you will be @ 190-195 whp tuned.
Good luck
Old Oct 1, 2004 | 05:31 PM
GOLDBERG's Avatar
nice #'s...run some 370's...or something like that...
Old Oct 1, 2004 | 10:45 PM
mtber's Avatar
What kinda of fuel pressure are you running ?
If your fuel pressure is above 50 psi at WOT & you are still maxing out your injectors, buy some rc 310s from Tom at lightningmotorsports.com
It would be nice if you had an a/f chart :-)
What are your camgears set at ?
What was your a/f target ?
Old Oct 4, 2004 | 10:25 AM
Shane54's Avatar
Default Re: (mtber)
cam gears are zeroed. As for the fuel pressure, I'm really not sure, unfortuantely I wasn't able to be there when it was being tuned.
I really appreciate the advice guys!, many thanks!
Old Oct 4, 2004 | 10:29 AM
Shane54's Avatar
Default Re: (mtber)
cam gears are zeroed. As for the fuel pressure, I'm really not sure, unfortuantely I was able to be there when it was being tuned.
Old Oct 5, 2004 | 10:09 AM
H22JEFFREY's Avatar
SELL IT j.k
Old Oct 5, 2004 | 11:16 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: LS/VTEC Dyno, what should i do next? (hybridvisionz)
I'm running Prelude injectors with my LSVTEC, 345cc OBD1s
What is your cam timing?
If you are still running a stock B16 IM I would upgrade to an ITR or AEBS. From what I've heard the AEBS manifold make more power over a type R, and they are cheaper. I might get one myself.
SioneSi
19
Sep 2, 2008 11:06 AM
LSVTEC 91 Civic
47
May 19, 2006 02:56 PM
1meangsr
31
Aug 10, 2005 10:50 AM
