Tips for fixing CRX climate control units
Old Oct 1, 2004 | 10:15 AM
Reelizmpro's Avatar
Default Tips for fixing CRX climate control units
Alright this thing is notorious for breaking and the problem is so common, I don't think I've EVER seen one that wasn't cracked in someone's car and a new unit is rediculously expensive. SO, I bought a cracked CRX unit for $15 (PO installed Civic unit) and glued it together. The weak spots are between the temp **** and buttons and also the rightside screw mount. So what I did in addition to supergluing the crack was use a lot of silicone behind the temp **** for support. Fill all the cracks and crevices around the temp ****, particularly the area between the **** and the blower switch. For the rightside screw mount I drilled a hole in the metal framing of the dash console and put a set screw into the side of the unit. Now the force of pushing the buttons is perpendicular to the screw instead of parallel. Very simple thing to do and made a huge difference in the overall rigidity. Sorry, don't have any pics...but hope this helps.
Modified by Reelizmpro at 7:34 PM 10/1/2004
Old Oct 1, 2004 | 10:20 AM
carnifex's Avatar
Default Re: Tips for fixing CRX climate control units (Reelizmpro)
i fixed one by using small 1/4 inch self tapping scres with 1/8 inch pilot holes. i jb welded over the tops of them and it is still working after 3 years with no more cracking. i like the extra screw idea. post some pics.
Old Oct 1, 2004 | 03:58 PM
EL Vap133's Avatar
I have an unbroken climate control.
Old Oct 1, 2004 | 04:01 PM
Dwight Schrute's Avatar
Default Re: Tips for fixing CRX climate control units (EL Vap133)
Vap* changes temp * crack...
Old Oct 1, 2004 | 06:18 PM
thumbtack's Avatar
I went to the junkyard and pulled three units... then combined the best components to make it an unbroken unit. just be careful about the hot/cold **** cables.... At the junkyard I just snipped them off the back off the unit. When I got home with them, I used a razor blade to cut the plastic off so I could remove the cables without damaging the plastic clips that hold them in place.
I paid a total of 14$ for all three units.
Old Oct 1, 2004 | 06:29 PM
Reelizmpro's Avatar
Default Re: Tips for fixing CRX climate control units (thumbtack)
$14 for 3 units??? damn i thought I got a good deal. Did one of them have an uncracked faceplate?
Old Oct 1, 2004 | 08:21 PM
EL Vap133's Avatar
Default Re: Tips for fixing CRX climate control units (drewthomas14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">Vap* changes temp * crack... </TD></TR></TABLE>
It's ok, I got another one in my garage, just waiting to be used.
Old Oct 2, 2004 | 10:46 PM
thumbtack's Avatar
all three of them had uncracked faceplates.... I just cannabalized them for other parts... buttons, hot/cold dial, hot/cold adjuster arm, etc etc.... just go to the junkyard... we have a yard called u-wrech-it and they charge the same price for each part no matter what car it came out of. Some parts can be expensive... They wanted 55$ for a turbocharger... I left it there and got one at a junkyard north of me for $25 (incl. gas to get there)
Maybe my junkyards are just cheap... I don't know, but for me some stuff is a little pricey for what condition some of the parts are in.
Old Oct 2, 2004 | 10:49 PM
2point2's Avatar
i took the pos right out... great place for gauges..
Old Oct 2, 2004 | 10:56 PM
Rywire's Avatar
I found a guy that makes face plates. PM me.
Ryan
Old Oct 3, 2004 | 11:33 AM
thumbtack's Avatar
Default Re: (2point2)
Do you drive your crx in the winter time? I do and I am very thankful to have those controls... I can't stand being cold. I hate Michigan... I need to move.
Old Oct 3, 2004 | 11:49 AM
2point2's Avatar
Default Re: (thumbtack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumbtack &raquo;</TD></TR><TR><TD CLASS="quote">Do you drive your crx in the winter time? </TD></TR></TABLE>
nope! too much salt and too many bad drivers. I drive my civic hatch that i got for $200 (trust me, it's worth $200 haha)
nomoreavril
Apr 11, 2008 10:33 PM
tims_89_crx
Feb 19, 2008 04:13 PM
oakpwr
Nov 1, 2006 02:00 PM
wood 1
Apr 20, 2006 10:19 AM
Blue-Civic-Hybrid
Dec 16, 2002 07:50 PM
