Rev Limiter
Old Oct 1, 2004 | 09:17 AM
honda94's Avatar
Default Rev Limiter
Hello to the forum. does the Honda Accord 94 model have a rev limiter and if so what can we do to eliminate it???
-Bionic-'s Avatar
Former Sponsor
Default Re: Rev Limiter (honda94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda94 &raquo;</TD></TR><TR><TD CLASS="quote">Hello to the forum. does the Honda Accord 94 model have a rev limiter and if so what can we do to eliminate it???</TD></TR></TABLE>
Yes, but why?
Old Oct 1, 2004 | 09:24 AM
honda94's Avatar
Default Re: Rev Limiter (-Bionic-)
I noticed that when i see how high my revs go, it surges between 4500 to 5000, I did change the fuel filter which did have a good amount of resistance. I noticed a better acceleration in fourth to fifth gear. It just seems slow to build up speed. Maybe its just that way. Do you know of any easy tuning tweaks for the Honda.
Old Oct 1, 2004 | 09:33 AM
JimBlake's Avatar
If you remove the rev-limiter on a stock engine, you'll find that it really doesn't make much power above there. You need something like a different camshaft (among other stuff) in order to actually make power up there.
Old Oct 1, 2004 | 09:36 AM
honda94's Avatar
Default Re: Rev Limiter (JimBlake)
I understand about modifying cams, aspiration, and such, but the rev limiter can only be removed electronically?
Old Oct 1, 2004 | 10:07 AM
sj993's Avatar
I don't know how it can be removed, but by the time you hit the rev limiter there is no more power, so what would be the point?
Old Oct 1, 2004 | 10:09 AM
FatJoe's Avatar
Default Re: Rev Limiter (sj993)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how it can be removed, but by the time you hit the rev limiter there is no more power, so what would be the point?</TD></TR></TABLE>
he wants to blow his engine up... thats all i can think of
Old Oct 1, 2004 | 10:12 AM
sillyboi's Avatar
Default Re: Rev Limiter (FatJoe)
in my knowledge, you will need to reprogram the ecu in order to remove the rev limiter, but i suggest that you leave it alone, no point, it'll **** your motor later.
Old Oct 1, 2004 | 10:49 AM
fw190bvi's Avatar
Default Re: Rev Limiter (sillyboi)
your car makes top power at 5500rpm....it redlines at 6k, and will have fuel cutoff a little over 7.....why would you EVER want to go higher???
Old Oct 1, 2004 | 11:23 AM
TOAB's Avatar
i think cut off in 5th gens is actually below 7... like just short of 6500... either way youre not making **** for power after you pass up the redline anyway. most F series motors dont make power like B's do... you dont have to wind it up to 5k+.
Old Oct 1, 2004 | 12:08 PM
fw190bvi's Avatar
Default Re: (TOAB)
ive hit 7.....it wasnt something i enjoyed......
Old Oct 1, 2004 | 12:11 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda94 &raquo;</TD></TR><TR><TD CLASS="quote">... but the rev limiter can only be removed electronically? </TD></TR></TABLE>It's a cut-off that's programmed into the ECU, so YES that's true.
You originally mentioned things like surging at 4500, which isn't going to change if you remove the revlimiter. You'll just discover how quickly it runs out of breath when you rev higher.
Maybe you should first think about what kind of goals & budget you have for tuning.
fixe15
Sep 24, 2013 03:39 AM
casper.hughes
May 19, 2008 08:38 PM
F22dreams
Dec 24, 2007 05:52 PM
Raven_Accord
Nov 26, 2007 01:00 PM
osuperjohno
May 3, 2004 07:54 PM
