launching and tire pressure(azenis)!!
Old Oct 1, 2004 | 08:05 AM
rice crispies's Avatar
Default launching and tire pressure(azenis)!!
I got a set of falken azenis' awhile back and have been experimenting with launching techniques. I cannot break a 2.20 60' no matter what i do! i was just curious if there was a sertain tire pressure possible lower than 22psi that would yield better times. the car makes under 190whp with the zex and i cant spray off the line due to tire spin. any help would be greatly appreciated!
Old Oct 1, 2004 | 09:13 AM
civickiller's Avatar
Default Re: launching and tire pressure(azenis)!! (rice crispies)
32psi, or whatever factory recommended psi
Old Oct 1, 2004 | 09:19 AM
TEAMGENDAI's Avatar
a 2.2 is already a pretty good 60' for the power you are making. you are doing a great job
Old Oct 1, 2004 | 11:24 AM
BolivianFuego's Avatar
Default Re: launching and tire pressure(azenis)!! (TEAMGENDAI)
Def. go lower then 22lbs. Try 18-20lbs. People have been able to pull 2.0 60fts with azenis. Try warming them up not where its wet for full blown slicks but next to it where its dry, and just give it a spin not a crazy burn out. Better luck next time out at the track.
Old Oct 1, 2004 | 12:40 PM
ModenaTwinTurbo's Avatar
Default Re: launching and tire pressure(azenis)!! (BolivianFuego)
what about that recent post where it was basically concluded that whatever the tires ask for is best for street tires as for psi is concerned, because of the strong sidewalls. u know that V or /\ thing?
Ed-
Old Oct 1, 2004 | 01:03 PM
MAD SOHC's Avatar
Default Re: launching and tire pressure(azenis)!! (ModenaTwinTurbo)
I've been able to cut 2.0s with Azenies at about 20-22psi. What you need to do is drive completley around the water and do a couple of dry launches. I might add they hook alot better the closer they are to bald. Also if you like drag racing never buy azenies again.......lol
Old Oct 1, 2004 | 01:11 PM
Default Re: launching and tire pressure(azenis)!! (MAD SOHC)
why do you say that?
Ed-
Old Oct 1, 2004 | 03:43 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SOHC &raquo;</TD></TR><TR><TD CLASS="quote">I've been able to cut 2.0s with Azenies at about 20-22psi. What you need to do is drive completley around the water and do a couple of dry launches. I might add they hook alot better the closer they are to bald. </TD></TR></TABLE>
i can cut a concistent 2.1 60' time with my 14" azenis, with the airpressure from 32-18psi. i actually never done a dry burnout with them, but i always roll them through the water box and burn out! i'll keep running them till they're bold, i hope that they can grip a litter better when bold
Old Oct 1, 2004 | 05:40 PM
all motor b20b's Avatar
Default Re: launching and tire pressure(azenis)!! (smokey2.0)
I had the tire pressure at 10psi and launched at 5 grand, and my 60fts were 2.0s.
Old Oct 1, 2004 | 06:01 PM
91civicDXdude's Avatar
Default Re: launching and tire pressure(azenis)!! (all motor b20b)
10psi on DOT radials is asking for bad news
Old Oct 1, 2004 | 06:49 PM
Suprdave's Avatar
Default Re: launching and tire pressure(azenis)!! (91civicDXdude)
Buy Slicks, thank me later.
Old Oct 1, 2004 | 07:10 PM
Default Re: launching and tire pressure(azenis)!! (Suprdave)
thanks alot for the advice. i just went to another local race track and it sucked! everything was the same on the car from last week and here is the 2 time silps:
tonight on 22psi last week is
60' 2.294 60' 2.201
330' 6.209 330 5.910
1/8 9.277 @ 81 mph 1/8 8.703@83.95
1/4 14.112 @ 102.76 1/4 13.519@102.84
that track was DOO DOO!!! do you guys think solid motor mounts would help! i plan on doing a b series swap so i already have gsr mounts in there. thanx once again for the advice!!!
Old Oct 1, 2004 | 07:12 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ModenaTwinTurbo &raquo;</TD></TR><TR><TD CLASS="quote">why do you say that?
Ed-</TD></TR></TABLE>
azenias wont last long if you drag race with them a lot
Old Oct 1, 2004 | 07:13 PM
and i forgot. ill NEVER buy azenis for drag use again!! they do very well on the street and in the turns but imo cant hold a candle to bfg's! lol
Old Oct 1, 2004 | 07:38 PM
silvervtecrx's Avatar
u can always go lower than 22 psi.. try 15 to 18 on them and launch from 4500 to 5000g.. nd go around the water box dont get ur tires wet (of which someone has already mentioned)..
Old Oct 1, 2004 | 09:58 PM
_entropy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice crispies &raquo;</TD></TR><TR><TD CLASS="quote">and i forgot. ill NEVER buy azenis for drag use again!! they do very well on the street and in the turns but imo cant hold a candle to bfg's! lol</TD></TR></TABLE>
I'm shocked, you mean a stiff sidewall tire deisgned for autocross and open track does not stick as well as BFG drag radials in a straight line?
Davidls
Jul 28, 2009 06:28 PM
98 ITR
Mar 18, 2007 10:43 PM
FerioVtec94
Feb 20, 2004 10:35 AM
C8V6C
Nov 7, 2003 09:44 PM
onyx00
Jun 9, 2002 07:24 PM
