Need Base Map for T3/T4E on Stock LS Motor
Old Oct 1, 2004 | 07:03 AM
spike's Avatar
Default Need Base Map for T3/T4E on Stock LS Motor
Going to be running Uberdata on an OBD1 B18B.. toyosuprs equal length mani with a t3/t4e w/ 60 trim - exhaust side is .63. Trying for 15psi daily.. just want to make sure we're not running too much time.. post your map if you have a similar setup please!
What's a good timing to be at that's somewhat safe but also making good power.. I'm hoping for 325whp or so..
TIA!
Old Oct 1, 2004 | 07:04 AM
spike's Avatar
Default Re: Need Base Map for T3/T4E on Stock LS Motor (spike)
We're starting the tuning on 450cc's and seeing how far we can push them.. we are then most likely going to upgrading to 720s.. how many hp are 450s good for?
Thanks again!
Old Oct 1, 2004 | 07:33 AM
toolowsol's Avatar
Hey bud, you should really just make your own basemap, that way you can see your injector duration etc, let me know if you want help with this And you will max out those 450's before you hit 325hp for sure Hit me up on an email and I'll help you make a great basemap.
Old Oct 1, 2004 | 10:12 AM
spike's Avatar
Default Re: Need Base Map for T3/T4E on Stock LS Motor (toolowsol)
can anyone post thier ignition and fuel maps that is running a Stock LS motor? Preferably along the 15 psi boost lines
Thanks!
Panda Eg6
May 16, 2008 08:20 AM
meotch
Nov 23, 2006 03:47 PM
SFlCrx
Oct 4, 2006 10:14 AM
adseguy
Jul 2, 2004 08:08 PM
Prelussion
May 30, 2002 07:49 AM
