how does this sound for an all motor street strip build
i plan on using this setup on the street and some weekend drags let me know what you think
gsr block 84mm bore ge sleeves 11:1 to 11.5:1 compression stock stroke or maybe ls crank 89mm stroke
gsr head port polish skunk 2 valve train
skunk intake manifold 68mm str throttle body
a good after market set of rods open to suggestions im thinking maybe eagle
now what cams would everyone suggest skunk 2 stage 2 or stage 3 im guessing stage 2
and i want to run a bisimoto header with a full 2.5 inch exhaust what would be the down falls of the use of this header on the street
and this is going into an 86 crx si only 1850 lbs full interior if that matters
please let me know what you think
thanks
thanks
I would go with the eagle rods i have them in my motor and i love the way they work and how dependable they are even when making a lot of power. As for the the cams def go with the stage 2, if you use the stage 3's ur not going to see the power out of them that you would like to see because your compression is too low. The stage 3's will turn you off on skunk products so def go with the stage 2's and you will be very happy!!
RaceCarRyne
Jan 14, 2006 07:14 AM
ActiveAero
Jan 18, 2004 10:03 AM
