OIL in cylinder one wtf!
Engine:JDM B16a 1st gen- Car: '93 dx4dr-
Was changing my spark plugs today, pulled out plug from #1 and there was oil in it, and on the plug threads, and oily deposits on my electrode (SOAB)! So I'm guessing its either a cracked cylinder, worn valve guides, or bad piston rings. Oh yeah other 3 cyl are showing normal wear. Any opinions???
See the thing is,....I just used seafoam last week, (vacum line/gas/crankcase etc... changed the oil the next day. So maybe seafoam is the cause??? I dont know it was my first time using the sh!%, it worked good tho, well besides the dumb *** neighbor calling the FIRE DEPARTMENT!!! and of course the two cops start ****** around, "Is that a legal set up, rev it for us, your muffler is "customized" is it dot approved 50 state legal,
I got annoyed got smart with 'em replied..."The liscense plate is ny, my inspection is ny,
my DRIVERS liscence is ny, hmmm, it must be legal in NY. got a ticket for disturbing the peace, and customized muffler- fu#$#@@$%%$@ Fart cans! had to vent
Modified by VTiVTo8000rpm at 2:13 AM 10/1/2004
you need to kick your neighbors ***. Did you make it clear to your neighbor after the cops left that you were pissed and he/she caused you to get a ticket?
i would say do a compression and leakdown test. usualy in the case of oil siting on top of the piston, its worn rings or theres a chance theres a crank in the head gasket. usualy if its a valve stem seal it wont allow oil to leak into the cylinder with the engine off. does it smoke when its running, or when you sit a light for a minute, and take off does it somke?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6gcivic »</TD></TR><TR><TD CLASS="quote">you need to kick your neighbors ***. Did you make it clear to your neighbor after the cops left that you were pissed and he/she caused you to get a ticket?</TD></TR></TABLE>
Tell me about it. She knows, she is an old crabby booger that needs to be flicked, but hellssssss yeah I let it b known I was all sorts of pissed off after cops left, its all good, my car is mad loud at 5500 she's in bed by 8ish every night need I say more? She offered to pay half so thats cool but still, I ******* HATE 0lD Pe0pLe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">i would say do a compression and leakdown test. usualy in the case of oil siting on top of the piston, its worn rings or theres a chance theres a crank in the head gasket. usualy if its a valve stem seal it wont allow oil to leak into the cylinder with the engine off. does it smoke when its running, or when you sit a light for a minute, and take off does it somke?</TD></TR></TABLE>
After i changed the plugs today was the 1st time she smoked at idle, not bad, just alittle clear white puffs smelled of gas.
accord2civic2prelude
Mar 11, 2009 07:49 PM
