Bronze Heliums + Yellow CRX = not TOO shabby.
Out heat-cycled the new victoracers and decided to snap some pics. Also, removed the mudflaps as the scrape when the 13x9s are on the car. Since the car was painted with the flaps on, i had to paint the now exposed area... painted it black, since it didn't stand out too much.
Then, i bolted on the 13x9s for preparation for a drag race tomorrow:
Maxine in the background... she gets special treatment, aka, the garage.
Almost looks mean. ha!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni »</TD></TR><TR><TD CLASS="quote">Can't even see the wheels...they could be steelies for all I know.</TD></TR></TABLE>
I see them.
Track ***** rock
I see them.
Track ***** rock
Agreed, but I guess its the thought that counts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens »</TD></TR><TR><TD CLASS="quote">
I'm running their 13x9 for autox.
With the 235-45-13 Kumho v700, they stick out from the fender a good 2 inches...on all four corners. Looks like a go-kart
exact same setup. I'm running 5.5" back spacing...
and sorry, the FRONT wheels on the "drag" setup, look exactly like steelies.
the rest... well, didn't think they were THAT dark. On the laptop, they looked bright, PC... boo hickey.
</TD></TR></TABLE>exact same setup. I'm running 5.5" back spacing...
Looks nice. Will you be running those Oct12 at the auto-x? I saw your car last time I went in Sept. That thing flys, looks like it was on rails.
btw, noob question. are the scca events auto-x or called something else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven »</TD></TR><TR><TD CLASS="quote">exact same setup. I'm running 5.5" back spacing...</TD></TR></TABLE>
What year CRX? It seems like it will hit the suspension in the back if I get 13x9 with 5.5" backspacing on my '89, I was planning on 5".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue.kangaroo »</TD></TR><TR><TD CLASS="quote">Well, what is the question here? THIS SHOULD BE MOVED TO APPEARANCE smart ***</TD></TR></TABLE>
Good point. I forgot to add that the wheel/tyre combo was 31lbs (got that down a few posts later after realising it was omitted).
Since there's some benefit from running lighter wheels/tyres... it therefore becomes "tech".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyz34 »</TD></TR><TR><TD CLASS="quote">Looks nice. Will you be running those Oct12 at the auto-x? I saw your car last time I went in Sept. That thing flys, looks like it was on rails.
btw, noob question. are the scca events auto-x or called something else.</TD></TR></TABLE>
AutoX is just a catchall for any autocross events. SCCA technically calls it "Solo2". "solo1" is like time trials/hpde stuff...depending on the region.
And yeah, i'll be at the 10/10/04 AutoX. Come out, i give rides to pretty much anyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohappy »</TD></TR><TR><TD CLASS="quote">
What year CRX? It seems like it will hit the suspension in the back if I get 13x9 with 5.5" backspacing on my '89, I was planning on 5".</TD></TR></TABLE>
it's a 1990. But, all 1988-1991 CRXs with CRX knuckles have similar offsets. I haven't had any rub problems. the 5" would stick out 6mm more...but you'll get 6mm more of space between your suspension.
a nice offset/wheel clearance calculator
Wheel Tech
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four »</TD></TR><TR><TD CLASS="quote">I love my Heliums! But my setup weighs 37lbs, with Azenis's. What tire you running? Is it street legal? </TD></TR></TABLE>
Azenis are a really heavy tyre for their size
I'm running 205/50-15 Victoracer V700s, they are 21lbs. The Falkens are 22-23lbs? and the Victoracers are one of the heavier R compounds.
and yes, victoracers are DOT legal... not recommended for street use though.
Wheel Tech
crxforum
Oct 15, 2010 11:07 PM
Jay J
May 20, 2003 05:10 AM
