Is my rear brake piston destroyed???
Old Sep 30, 2004 | 06:48 PM
OBD1Kenobe's Avatar
Default Is my rear brake piston destroyed???
I recently bought a 94 GSR and the time came for a new set of rear pads.
When I took the RR caliper off, I was shocked to see a completely torn and tattered piston boot (rubber sealything). After removing what was left of the boot I examined the piston and I'm not too optimistic about what I saw...
The very end of the piston (near the + end) is nice and shiny, but back further (towards the caliper) there is a ****-ton of corrosion on the piston. It looks like the boot had been torn for quite awhile.
I haven't done anything with it yet. Obviously I need a new boot. I am scared to screw the rusty section of caliper back into the caliper body though. Would this damage the walls and destroy the caliper body? Can I "clean up" the piston? Is it already beyond rescue?
TIA for any insight or advice....
Old Sep 30, 2004 | 07:45 PM
OBD1Kenobe's Avatar
Default Re: Is my rear brake piston destroyed??? (OBD1Kenobe)
Bump before bed...
Nobody's seen this happen before?
Old Sep 30, 2004 | 08:15 PM
aw1234dude's Avatar
I don't know if this helps you any but you can get completely rebuilt calipers from places like napa or autozone for like 50-70 bucks with the core charge. I had to change out one of my front calipers and it was about 70 bucks so I'm guessing the rears should be alot cheaper.
Old Sep 30, 2004 | 08:17 PM
tremor86's Avatar
option 1:get a caliper rebuild kit and a brake cylinder hone from an autoparts store or the dealer. rehone the cylinder to remove the corrosion and rust, order a new piston if you have to from the dealer. assemble the caliper and bleed the line.
option 2: get a new caliper from the dealer ($) or get a remanned caliper from an autoparts store for cheap. install either and bleed the line.
I would go with option 2, its supprisingly cheap to get a remanned caliper and its alot less labor intensive than rebuilding your own.
mfrs
Sep 9, 2014 03:49 PM
kidcool1977
Nov 30, 2008 05:42 AM
Dunc
Jul 2, 2008 09:22 PM
shutta
Mar 29, 2006 06:01 AM
maxdb
Apr 28, 2005 04:16 PM
