lsvtec questions
I need some help with my lsvtec build. I am getting alot of advice from alot of people who have experience building them but they all have thier opnion of what I should do.
I already have these parts.....
97 ls block
00 b16 p&p head,98 gsr head... thinking of the b16 one to put in
golden eagle full vtec conversion kit
ctr pistons
ctr cams
bored 65mm b16 tb
obd2 dizzy
vtec water pump
99 gsr ecu
gsr intake manifold
That is what I got now. I know I need an im,header,exhaust.
What I want to do is to have a full lsvtec.
What else do I need to have a complete lsvtec.
What should I do to the block before I put on the head?
If you have any suggestions on what brand of parts I should go with is welcome. Any suggestions are welcome.
I need all the help I can get....shops..websites for parts...I live in ny so If you got any suggestions tell me
97 ls block
ctr pistons
ctr cams
bored 65mm b16 tb
obd2 dizzy
vtec water pump
99 gsr ecu
gsr intake manifold
Get ARP rod/head studs, and upgrade your valvetrain to a crower or equivalent... for reliability issues. Balance the bottom end if you have everything apart. Invest in a good tuning platform too, like a Hondata or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloysr16s »</TD></TR><TR><TD CLASS="quote">THANKS
WHAT SHOULD i do to the bottom end ?</TD></TR></TABLE>
Keep the LS Bottom, get it blueprinted/balanced, use ARP rod bolts.
if its done right it will be fine, use the search and also check out c-speedracing, they have a good lSvtec write up. Theres alot of info out there if you look for it. Good luck
I JUST GOT DONE WITH A LS/VTEC
B18A,CRANK AND RODS
P72 HEAD, WATER PUMP, OIL PUMP, TIMMING BELT
SKUNK 2 INTAKE MANIFOLD
ARP HEAD,ROD.MAIN STUDS
CTR PISTONS(.25 OVER BORE), CRANK PULLY
ITR HEADER
BALANCE ROTAING ASSY.(MUST)
BLOCK AND HEAD DECKED TO MATCH
I USED A COMIC HEAD GASKET TO LOWER THE CR TO ABOUT 12:3-1
PR3 ECU FOR NOW, GOING TO GET P28 HONDATA S200
B18A,CRANK AND RODS
ITR HEADER
With the setup that I have what should i use and not? What I wnat is to build the car for daily driving. I need reliabilty.
Out of my list is there anything I still need ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloysr16s »</TD></TR><TR><TD CLASS="quote">if my comp is high dont i have to have like 110 fuel in my car
Im on 110-116 with 14.5:1 compression ratio
well the thing is that 110- 115 is hard to come by over here . The fuel is like 6.50 a gallon. I was wondering what would keep my compression down . I want something where i dont have use 110-115. 93 is fine with me if possible
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloysr16s »</TD></TR><TR><TD CLASS="quote">wanna lower your compression,get an thicker headgasket
which headgasket should I use?</TD></TR></TABLE>
OEM Honda 3 layers work fine.
go with a high compression, then kick back ur ignition timing to run 93 octane... then when that lil turbo civic down the street gives u **** for being slow, find some 110 and advance the ignition timing.
<- planning on 13:1 compression, daily driver, 93 octane, full hondata.
