Will an IAT sensor make your RPMs surge?
Old Sep 30, 2004 | 06:11 PM
89teg's Avatar
Default Will an IAT sensor make your RPMs surge?
This is my main question, will an IAT sensor malfunction do this or is there something more to this that sucking up water through my intake caused.
I hit a large puddle and sucked up a ton of water. Hydrolocked the motor, threw a rod and replaced the longblock. My car ran perfect before the mishap, so it must be a sensor fouled up somewhere. My computer is no help though, it keeps reading 10.
Modified by 89teg at 7:36 PM 9/30/2004
Old Sep 30, 2004 | 06:22 PM
handa's Avatar
Default Re: Will an IAT sensor make your RPMs surge? (89teg)
not at all. i know mine didn't. some other ones that may cause rpm surge could be map sensor and iacv.
Old Sep 30, 2004 | 06:27 PM
89teg's Avatar
Default Re: Will an IAT sensor make your RPMs surge? (handa)
What would most likeley be damaged due to water passing through when my intake sucked up water?
Also it only surges when I give it gas, not at idle
Yes hydrolock
I can only post five messages as a trial user, heeeeeeeeeeeeeeeeeeeeeeelp!!!!!
Fuel filter should be fine, no water could've got in there. Will put in new plugs, check the TPS, and cap and rotor. Maybe it could be one of those but it's weird, only when I give it gas does it do that. When I rev past the point of it surging into the higher rpms it goes away.
Modified by 89teg at 7:53 PM 9/30/2004
Modified by 89teg at 7:54 PM 9/30/2004
Old Sep 30, 2004 | 06:29 PM
green-'s Avatar
hydrolock?
handa's Avatar
oooh a hydrolock...or similar.
i've never experienced one, so someone please help 89teg out.
Old Sep 30, 2004 | 06:39 PM
mike1jag's Avatar
hydrolock..not good seen one break a rod.it sounds like your icv is acting up. but it would only do it at ideal.are you getting a check engine light? also check your fuel filter.
Old Sep 30, 2004 | 06:44 PM
mike1jag's Avatar
ok sorry didnt see the check light code ten. did you put in new plugs? also if you are running apc plug wires they have a tendency to go bad after a while.cheap crap sucks.look at your cap and rotor button to see if they are rusty.also your throttle postion sensor couldhave gotten wet.
Old Oct 1, 2004 | 07:32 PM
89teg's Avatar
Default Re: Will an IAT sensor make your RPMs surge? (mike1jag)
I fuigured it out. Really stupid. I switched the connectors for the IAT and the IACV sensors. I didn't even know they were the same until I did a lot of reading on the honda-acura.org archives. You would think that the engineers at honda would change the plugs slightley so that wouldn't be an issue. On every other fuel injection harness I've ever delt with no connecter is the same. Oh well, live and learn. Car seems to be running fine now.
Old Oct 1, 2004 | 07:36 PM
bushfreakz's Avatar
maybe tps as well
n/m you got it
Old Oct 1, 2004 | 07:38 PM
PRcivicHB's Avatar
I did that one time when i was swapping IM... Took me weeks, no, months to figure that shyt out... I thought it was my IACV... I felt like an airhead when i figured the plugs were crossed....
Old Oct 3, 2004 | 06:28 PM
89teg's Avatar
Default Re: Will an IAT sensor make your RPMs surge? (PRcivicHB)
The problem is still there somewhat. I need to know the colors of the wires going to each connector. That would give me some peace of mind.
ls_vtec95
Nov 18, 2010 05:25 AM
bvilleteggy62
Aug 14, 2007 03:53 PM
Carbcivic
Mar 26, 2006 01:52 PM
ahloung
Mar 15, 2006 11:59 AM
