Welp, Its toast.
Old Sep 30, 2004 | 05:50 PM
CRseXy's Avatar
Default Welp, Its toast.
Welp, my Clutch is Toast. I think. My Tranny is making a nice clunking sound.AND its leaking. I got a DX Tranny. so Im thinkin of swaping the SI trans in it. What am I going to need??? Im in need of some Despret help.
Old Sep 30, 2004 | 05:51 PM
dr_latino999's Avatar
Default Re: Welp, Its toast. (pogiTSI)
New clutch, maybe pressure plate, resurface or new flywheel and time
Old Sep 30, 2004 | 06:20 PM
CRX T-Si's Avatar
Default Re: Welp, Its toast. (dr_latino999)
Make sure you get the clutch for the flywheel. The 88 is different size, 89 is one and 90-91 is another one.
Old Sep 30, 2004 | 06:31 PM
CRseXy's Avatar
Default Re: Welp, Its toast. (CRX T-Si)
Thanks yall, So I get the fly wheel from the same year SI. Clutch. shift linkage, Axles are all the same right????
Old Sep 30, 2004 | 08:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">Thanks yall, So I get the fly wheel from the same year SI. Clutch. shift linkage, Axles are all the same right????</TD></TR></TABLE>
Yup
Old Sep 30, 2004 | 09:11 PM
CRseXy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">
Yup </TD></TR></TABLE>
k, what about starter? do you think ill run into problems with the SI tranny, and my Dual Point Injection???? dont really wana run into any problems later.
Old Sep 30, 2004 | 09:18 PM
Starters are all the same, well as long as they are for a manual
No problem with the DPFI, should be an interesting ride though.
Old Sep 30, 2004 | 09:36 PM
CRseXy's Avatar
k, Do you think I should get a junk yard Fly wheel? or go Aftermarket? I kinda need to go cheep. What Clutch Should I order???? 1.6 right? thanks for all the help guys.
clutchdown_89
Transmission & Drivetrain
Aug 19, 2011 07:20 AM
tico
Sep 15, 2008 11:12 PM
dwerpk
Jun 5, 2006 05:09 PM
racingant
Sep 6, 2004 08:08 PM
Gant
15
Feb 17, 2004 03:01 PM
