left lights on over night on my optima yellow top, jump it and everything is fine turn it off, and n
Old Sep 30, 2004 | 05:41 PM
ewing86's Avatar
Default left lights on over night on my optima yellow top, jump it and everything is fine turn it off, and n
Heres the thing, i drop my rex off at the inspection station the other night, its got a b16a in it and the battery is relocated to the rear. It passes and everything is cool, I get in it to drive home and turn the key and nothing happends no lights nothing. I go back to the guy and he said he had a battery jumper so he jumps it and everything is fine.(see what happened was he left the lights on for like a 24 hour period because when i got in it the switch was still turned on for the lights to be on). anyways i drive a half hour home and turn the key off then just to make sure everything was cool i click it over to see if the dash lights come on and nothing, not even faded lights nothing. so i go to jump it and nothing is making it work. no lights no dash lights doesn't turn over obviously. so i'm stumped now and the only thing on the car that still works are the hazards so i have no idea what to do, please help?
Old Sep 30, 2004 | 05:47 PM
91sihatchback
Guest
Posts: n/a
make sure everything is wired up correctly and he didnt tamper with your ****, jump your battery and drive the car around a while..or charge it if you can, check your fuses too
Old Sep 30, 2004 | 05:49 PM
ewing86's Avatar
Default Re: (91sihatchback)
i keep going over the wiring and it all looks good checked all fuses and still good, the only thing that is weird is why are the hazards working and nothing else.
hotnsticky5100
Mar 2, 2018 09:01 AM
Bikerxgames420
Sep 3, 2007 11:24 PM
asianalbutt
Feb 20, 2007 12:34 PM
GraphiteMW
Dec 24, 2006 01:27 PM
rob_dogg55
11
Nov 15, 2006 09:03 PM
