interior lights out , and cig lighter?
Old Sep 30, 2004 | 03:43 PM
DarkBB4's Avatar
Default interior lights out , and cig lighter?
Hey whats the problem fellas? i checkd under my hood in my fuse box..a nd Im not really sure what i shodlbe lookin for ..> I made sure they were Alll Popped in, but they all were?
anthing else i can do?
Old Sep 30, 2004 | 04:05 PM
LudeyKrus's Avatar
Are your gauges out too? If so, you're taillights prob. are too.
Check the underhood fuse labelled "small light(s)".
Old Sep 30, 2004 | 04:08 PM
DarkBB4's Avatar
Default Re: (LudeyKrus)
i know but do i have to replace it .. or waht do i do?
and where do i go?
all ive figured out so far is.. the Little Key light is out, dome lights, cig lighter, um... When i turn on and off my lights the guages dont light up.. but when i start the car they do
Old Sep 30, 2004 | 04:19 PM
LudeyKrus's Avatar
Hmmm...........they come on when you start your car?
Well check that fuse anyways.
Look under the hood of your car. At the top left, near the windshield, there will be a fuse box. Pull the cover off. Somewhere towards the middle of the top row there is a 10A or 15A fuse; check the diagram on the fuse cover you pulled off. Look for the one labelled "small light(s)" and pull it out. Look at it and see if it's blown. If so, you've found your problem; replace the fuse, and see if it pops it again. If it's not blown, go through and check the other fuses anyways.
Old Sep 30, 2004 | 04:53 PM
DarkBB4's Avatar
none of them were Popped!?!!!
wierd?
I checekd them anyways and they all appeared to be Ok... ( just look normal)
and i checkd the interior fuse as well and Nothing there either
I was ******* aroudn with something today (cig lighter... wiring in a neon ) and i knew that if i screwd it up,. it would pop a fuse but now ITS NOT POPPING??
Old Sep 30, 2004 | 05:39 PM
DarkBB4's Avatar
Default Re: (DarkspeedVtec95)
help lease
Old Sep 30, 2004 | 07:08 PM
ichibanjap's Avatar
Check all the fuses with a tester, one of them is blown. Or you could do it the hard way and pull them all out one by one. Make sure it's still connected in the middle.
Old Oct 1, 2004 | 02:43 AM
Humlae's Avatar
Default Re: (ichibanjap)
Something similar happen to me too. For mine it was the interior lights fuse. Try checking that, it either should be 10A or 15A and you can get it at Kragen, Autozone etc...
Old Oct 2, 2004 | 11:11 AM
PrettyLude's Avatar
its the interior lights fuse
Old Oct 2, 2004 | 01:04 PM
DarkBB4's Avatar
Default Re: (PrettyLude)
fixed.. 15A thanks guys
1 jonesie
Jul 14, 2006 02:18 PM
gsrcivic619
Mar 23, 2006 10:53 AM
Rayog21
Sep 21, 2005 08:38 PM
Ancient
Apr 19, 2005 08:18 AM
Orison21
Feb 21, 2004 03:28 PM
